Author Topic: Help : filter dimension layer  (Read 448 times)
mhy3sx
« on: June 30, 2024, 01:32:13 PM »
Hi I want to to search the drawin and if any dimensions in the drawing to move them to layer DIM, but if not any dimensions to
    (princ "No dimensions found.")
and aboard the code.
The code bellow works perfect if dimension exist in drawing , but if there is no dimension gives me this error
Current layer: DIM
Enter an option [?/New/Make/Set/Color/Ltype/LWeight/Plot/ON/OFF/Freeze/Thaw/LOck/Unlock/Rename/Description/DELete/stAte/TRansparency]: DIM
Invalid keyword.
  1. (defun c:DLDL (/ sel1 CLAYER )
  2.    (command "_.Tilemode" 1) ; ;Switch from Layout Tab To Model Tab before stating LISP
  3.
  4.   (if (setq sel1 (ssget "X" '((0 . "DIMENSION") (-4 . "<NOT") (8 . "ARROWLINE") (-4 . "NOT>")))) ; SELECT ALL DIMENSION
  5.      (progn
  6.       (setq OLDLAYER (getvar "CLAYER")) ;GET CURRENT LAYER
  7.       (setvar "CLAYER" OLDLAYER) ; SET ACTIVE LAYER TO PREVIOUS
  8.
  9.          (if (=(tblsearch "layer" "DIM") nil)
  10.       (command "_layer" "_m" "DIM" "_c" "7" "" "_lw" "0.30" "" "")
  11.      );end if
  12.
  13.       (command "CHPROP" sel1 "" "LAYER" "DIM" "")  ; CHANGE DIMENSION LAYER TO NEW LAYER
  14.       (command "._draworder" sel1 "" "_f")
  15.           (command "-DIMSTYLE" "R" "STANDARD")
  16.      );end progn
  17.     (princ "No dimensions found.") ; Handle case when no dimensions are selected
  18.   );end if
  19. ;Layer 0
  20. (mapcar 'setvar '(clayer cecolor celtype celweight) (list "0" "BYLAYER" "BYLAYER" -1))
  21.     (princ)
  22. )
  23. );end def
  24.
mhy3sx
Re: Help : filter dimension layer
« Reply #1 on: June 30, 2024, 05:12:58 PM »
I update  hte code , but gives me
Command: DLDL
Invalid keyword.
Error: Function cancelled
  3.
  5.      (progn
  8.
  11.      );end if
  12.
  16.      );end progn
  18.   );end if
  19. ;Layer 0
  21.     (princ)
  22. );end def
  23.
  24.
  25.
Any ideas?
ribarm
  • Marko Ribar, architect
« Reply #2 on: June 30, 2024, 05:49:07 PM »
You don't need lines 6 and 7... And you don't have CLAYER variable to localize it in (defun...( / ... ))
M.R. on Youtube
mhy3sx
« Reply #3 on: June 30, 2024, 06:00:56 PM »
Thanks  ribarm .  :smitten:
