Author Topic: 7zip via lisp  (Read 1234 times)
domenicomaria
7zip via lisp
« on: June 19, 2024, 04:08:16 AM »
since I need to save a copy of two folders every day
by compressing them into a 7zip file,
I would like to automate this procedure with lisp
Is there anyone who can give me some suggestions?
Thank you
dexus
Re: 7zip via lisp
« Reply #1 on: June 19, 2024, 04:31:00 AM »
It's not 7zip, but if a regular zip file would work as well you can start here: https://www.theswamp.org/index.php?topic=58636.msg616688;topicseen#msg616688
VovKa
  • Ukraine
Re: 7zip via lisp
« Reply #2 on: June 19, 2024, 04:55:28 AM »
(startapp "full path to 7z.exe" "a \"D:\\dest file 1.7z\" \"D:\\src folder\"")
Re: 7zip via lisp
« Reply #3 on: June 19, 2024, 10:01:50 AM »
I had one a while back I made to demonstrate.
https://www.theswamp.org/index.php?topic=14793.msg178860#msg178860
BIGAL
  • 40 + years of using Autocad
Re: 7zip via lisp
« Reply #4 on: June 19, 2024, 08:26:39 PM »
This is opposite an unzip using powershell.
(startapp (strcat "powershell -command Expand-Archive -Path '" filename "' -DestinationPath 'C:/CAD-TOOLS' -FORCE"))
Pretty sure should be a ZIP syntax. https://learn.microsoft.com/en-us/powershell/module/microsoft.powershell.archive/compress-archive?view=powershell-7.4
domenicomaria
Re: 7zip via lisp
« Reply #5 on: June 20, 2024, 02:57:08 AM »
thanks everyone...
... I have to do my own tests...
domenicomaria
Re: 7zip via lisp
« Reply #6 on: June 20, 2024, 04:01:13 AM »
I need to compress 2 folders in 1 7zip file
So I need, first of all, to compress the first folder into a destination file (7z)
and then repeat the same thing for the second folder,
always adding it to the same destination file
but STARTAPP DOES NOT WAIT for the first process to finish.
So the second process begins without waiting the end of the first one.
And then something goes wrong and the result is that
the second folder is not added to the destination file
with dos_exewait, however, it works
I should know what the syntax is for the 7zip command
to add multiple folders (a list of folders) all in the same destination file
and this only with 1 command
  1. (defun c:7Z ( / cdate dd dst-ffn mm src-fldr-1 src-fldr-2 yy)
  2.    (setq cdate (rtos (getvar "cdate") 2 0) )
  3.    (setq yy (substr cdate 3 2)
  4.          mm (substr cdate 5 2)
  5.          dd (substr cdate 7 2)
  6.    )
  7.    (setq cdate (strcat dd mm yy) )
  8.
  9.
  10.    (setq dst-ffn  (strcat "G:\\@\\VLISP22-DDI-" cdate ".7Z")
  11.          src-fldr-1 "G:\\@\\VLISP22\\"
  12.          src-fldr-2 "G:\\@\\DDI\\"
  13.    )
  14.    (if (findfile dst-ffn) (vl-file-delete dst-ffn) )
  15.
  16.    (dos_exewait (strcat "C:\\Program Files\\7-Zip\\7Z.exe" " a "dst-ffn " " src-fldr-1) )
  17.
  18.    (dos_exewait (strcat "C:\\Program Files\\7-Zip\\7Z.exe" " a "dst-ffn " " src-fldr-2) )
  19.
  20. )
  21.
« Last Edit: June 20, 2024, 04:06:58 AM by domenicomaria »
VovKa
  • Ukraine
Re: 7zip via lisp
« Reply #7 on: June 20, 2024, 07:43:31 AM »
(startapp "full path to 7z.exe" "a \"D:\\dest file.7z\" \"D:\\src folder 1\" \"D:\\src folder 2\"")
domenicomaria
Re: 7zip via lisp
« Reply #8 on: June 20, 2024, 01:12:20 PM »
Thank you VovKa.
It works well.
however it would be interesting to find a way to emulate dos_exewait...
... but this is another matter ...
domenicomaria
Re: 7zip via lisp
« Reply #9 on: June 20, 2024, 01:41:21 PM »
I say this, because after compressing 2 folders into 1 7zip file,
I need to copy this file to another hard disk...
... and vl-file-copy doesn't wait for the process started by startapp to finish...
...and so I still use dos_exewait !
PKENEWELL
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
ribarm
  • Marko Ribar, architect
Re: 7zip via lisp
« Reply #11 on: June 21, 2024, 10:37:34 AM »
I think that you don't need to use : dos_exewait...
Maybe this is what you are after :
(while (not (findfile fullpath+filename+ext))
(vl-file-copy fullpath+filename+ext dest-fullpath+filename+ext)
HTH.
M.R. on Youtube
domenicomaria
Re: 7zip via lisp
« Reply #12 on: June 22, 2024, 12:28:28 AM »
HTH.
it's an idea !
