(defun c:xdtb_hapath (/ ang box clr ha ha1 pat remove scl ss tm x)
(xd::doc:getdouble (xdrx-string-multilanguage "\n上方距离" "\nDistance above") "#xd-var-global-up-dist"
10.0
(xd::doc:getdouble (xdrx-string-multilanguage "\n下方距离" "\nDistance below") "#xd-var-global-down-dist"
10.0
(if (setq ha (xd::odcl:hatchdlg1 "" "" 1))
(setq pat (cadr (assoc "Pattern" ha))
remove (cadr (assoc "RemoveBoundary" ha))
scl (cadr (assoc "Scale" ha))
clr (cadr (assoc "Color" ha))
ang (xdrx_math_degtor (atof (cadr (assoc "Angle" ha))))
tm (atoi (cadr (assoc "Transparency" ha)))
(if (setq ss (xdrx-ssget (xdrx-string-multilanguage "\n拾取路径多段线<退出>:"
"\nPick Path Polyline<Exit>:"
) '((0 . "*polyline") (-4 . "&=")
(70 . 0)
(xdrx-begin)
(xdrx-sysvar-push '("BoxFillet" 1))
(mapcar
'(lambda (x)
(setq box (xdrx-getpropertyvalue x "tobox" #xd-var-global-down-dist #xd-var-global-up-dist 0.0
0.0
(setq ha1 (xdrx-hatch-make (xdrx-polyline-make box t)))
(xdrx-setpropertyvalue ha1 "PatternName" pat "PatternScale" scl "PatternAngle" ang "color" clr
"Transparency" tm
(if (= 1 remove)
(xdrx-entity-delete (xdrx-getpropertyvalue ha1 "assocobjids"))
(xdrx-ss->ents ss)
(xdrx-sysvar-pop)
(xdrx-end)
