Align Multiple Text Objects to Curve
encepta:
Problem: I need to align multiple text objects to curve.
LeeMac's DTCurve does exactly what I need but it only allows one text to be aligned at a time...
Any thoughts/ideas? I do not want to loop this function because that also results in a ton of clicks.
https://www.lee-mac.com/dtcurve.html
Lee Mac:
Try this old program -
https://www.cadtutor.net/forum/topic/47595-text-align-amp-delete-lisp-routine/#comment-390758
xdcad:
You can specify the distance after alignment
https://www.theswamp.org/index.php?topic=59245.0
reyas1123:
--- Quote from: xdcad on April 15, 2024, 09:13:06 PM ---
--- End quote ---
Dear Sir,
i downloaded the file and save to lsp file but has an error. tnx
ReyAs
xdcad:
--- Quote ---
Dear Sir,
ReyAs
--- End quote ---
Have you downloaded the API compressed package at https://github.com/xdcad/XDrx-API, decompressed it, and installed the files inside?
During installation, check all of them. After installation, start ACAD and check with F2. There will be a prompt whether the API is loaded.
│ ≡ XDRX_API For AutoCAD Build 2024.04.28 ≡ │
│ http://www.xdcad.net Mail:7598165@qq.com │
If normal,
It is possible to run the forum LISP
Navigation
[0] Message Index
[#] Next page
Go to full version
