Ok I've started a thread maybe a half dozen times and I've figured out my answers. I am bitting the bullet and just putting a place holder here in case I need a quick question answered.
Thank you for the indulgence.
I am starting my 2025 custom AutoCAD package. If it's all right with you all I will do one thread for many questions I am sure I'll have.
My first line in my cuidoc lisp is
(setq var1 (getenv "DCEload21"))
(if (/= var1 "loaded")
(load "\\\\dce\\designdata\\cadd\\dc acad\\default\\general\\support\\Enterprise 2021\\2021 DCE Profile.lsp")
(princ var1)
The profile lsp does one time things.
Like
Sets Trusted Paths: Sets trusted paths for AutoCAD so that Lisp files don't face challenges.
Folder Existence Check: Defines a function to check if a folder exists locally and create it if it doesn't.
Sets Support Paths: Specifies support paths and working paths for various AutoCAD functionalities.
Loads the Enterprise Menu Configuration:
Sets Help File Pathing: Specifies the location of the help files.
Adds the location of our custom dictionary file.
Sets Printer Configuration Paths: Specifies paths for printer configurations.
Sets Plot Style Table Paths: Specifies paths for plot style tables.
Sets Automatic Save Location: Sets the location for automatic saving of files.
Sets Drawing Template File Location: Specifies the location of drawing template files.
Sets Default Template File Name: Specifies the default template file name for new drawings.
Sets Log File Locations: Sets locations for various log files.
Sets Save Version of AutoCAD: Sets the save version of AutoCAD.
Sets Various Variables: Sets various AutoCAD variables needed for operations.
Setts Additional Variables: Sets additional optional variables to aid in work.
Changes Screen Colors: Changes screen colors for model space background, command area, and crosshairs.
Adjusting Layer Isolation: Adjusts layer isolation settings.
Sets Registry Value I can update values if needed.
AutoCAD's new Custom Install looks to only use an arg file as it's configuration file. Anyone foresee a problem with pathing for an enterprise setup?
If anyone has suggestions before I ask questions please feel free to help.
Finally !
