Author Topic: remove all comments  (Read 564 times)
domenicomaria
remove all comments
« on: March 27, 2024, 05:40:07 AM »
is there any utility to remove all comments in a large lsp file?
Lonnie
Re: remove all comments
« Reply #1 on: March 27, 2024, 05:38:18 PM »
How large?
chatgpt will let you put a lisp in up to a maximum limit for input text is 4096. It will clean and comment pretty well. I often use it to write my header.
Lastknownuser
« Reply #2 on: March 28, 2024, 02:19:00 AM »
Notepad++
CTRL+H
Find what: ";.*"
Replace with: empty string ""
Replace all
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: March 28, 2024, 10:51:00 AM »
I had one in .EXE, but it doesn't run (1991) lol
Id bet common lispers have one
kozmos
« Reply #4 on: March 28, 2024, 11:08:17 AM »
The very old LISPTOOL can do this job, but it doesn't support ;|.......|;
KozMos Inc.
« Reply #5 on: March 28, 2024, 06:24:27 PM »
Not sure why you'd want to do this but your text editor should be able to do this as Lastknownuser pointed out.
Just made one in C. Reads a directory of files and outputs to a new file while skipping all comment lines.
« Reply #6 on: March 28, 2024, 06:42:14 PM »
Notepad++
CTRL+H
Find what: ";.*"
Replace all
Consider semi-colons in string literals, and multiline comments.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #7 on: March 28, 2024, 06:59:35 PM »
. . . and inline comments
  1.
  2. (setq painInTheButt ;|some note here|; (getvar "petPeeves"))
  3.
  4.
Called Kerry in my other life
I live at UTC + 13.00
It's Alive!
  • Retired
  • AKA Daniel
« Reply #8 on: March 28, 2024, 07:36:51 PM »
When I first started using lisp, I’d have a version with comments and extra whitespace in the code removed, thinking it would run faster.
I was like compiling bro :lol:
BIGAL
  • 40 + years of using Autocad
« Reply #9 on: March 28, 2024, 08:32:58 PM »
Bit like on another forum a poster uses tabs and indents code problem is it pushes so far to right code disappears. I try to use 2 spaces rather than tab. Again use \t in search.
It would be pretty easy if comments are always to right -> end of line single lines, to write a lisp using Vl-position and substr writing to a temp file, option delete original or put some where else, then rename back to original.
« Last Edit: March 28, 2024, 08:47:13 PM by BIGAL »
kdub_nz
  • SuperMod
« Reply #10 on: March 28, 2024, 09:49:43 PM »
. . .  :lol:
and you believed in the Easter bunny too ?
