I really wish you would state what you are trying to do using complete thoughts. It looks like you are trying to replace some text AND save a COPY of the drawing. In the thread I linked to I gave an updated text find and replace that I've used many times. A save as is easy to do. Using packages like dos_lib to parse a path string is unnecessary and probably not going to work in accoreconsole. You keep typing your hands with these odd snippets and then blame the tool.
I don't blame ACCORECONSOLE ...
I am only trying to understand
what Is possibile to do with
ACCORECONSOLE
this is my complete and simple thought
but I saw that the ARX files cannot be loaded,
the VLA-XXX functions
and the VLAX-XXX functions do not work,
ENTMOD, ENTUPD and perhaps
ENTMAKE (this last function is not I've tested it yet)
they don't work...
and so I'm wondering what good can be done....
and it's certainly one more possibility...
because something can be done...
but I expected that they weren't there all these limitations
but
when I asked you if there were any LIMITATIONS...
when I asked you if EVERYTHING could be done,
you got angry and told me
to be clear and to say clearly that I didn't want your help...
but there is NO RELATIONSHIP
between the TWO THINGS...
if I write something it is only because
I try to understand something
and this means that anyone who helps me
to understand something is welcome...
there are no hidden thoughts,
hidden purposes but everything
is very simple...
have a nice day
