(defun c:xdtb_curvesubjc (/ pmid pts p1 e p2 dbpl spa epa mpa pnt clr p2 berase e1)
(defun _callback (dynpt)
(if (or (and p1 (not (equal p1 dynpt)))
(and pmid (not (equal pmid dynpt)))
(progn (setq spa (xdrx-curve-getparamatpoint e p1)
pnt (xdrx-curve-getclosestpoint e dynpt)
epa (xdrx-curve-getparamatpoint e pnt)
mpa (if pmid
(xdrx-curve-getparamatpoint e pmid)
(/ (+ spa epa) 2.0)
(setq pl (xdrx-curve-setinterval e spa epa mpa))
(if (not (xdrx-object-iskindof pl "kcompositecrv3d"))
(setq a (xdge::constructor "kcompositecrv3d" pl))
(xdge::free pl)
(setq pl a)
(setq data (xdrx-getpropertyvalue pl "get"))
(xdrx-setpropertyvalue dbpl "set" data)
(xdrx-setpropertyvalue dbpl "constantwidth" #xd_var_global_width "color" clr)
(xdrx-grdraw clr dbpl)
(xdge::free)
(xdrx_begin)
(xdrx_sysvar_push '("osmode" 547))
(setq pts nil)
(if (not #xd_var_global_width)
(setq #xd_var_global_width 1.0)
(if (setq var (getreal
(xdrx_prompt (xdrx-string-formatex (xdrx-string-multilanguage "\n输入加粗宽度<%.2f>:"
"\nEnter bold width<%.2f>:"
t
(setq #xd_var_global_width var)
(if (and (setq e (car
(xdrx_entsel (xdrx-string-multilanguage "\n选择曲线实体<退出>:"
"\nSelect Curve Entity<Exit>:"
'((0 . "*line,arc,circle,ellipse"))
(if (xdrx-object-iskindof e "AcDbSpline")
(progn (setq e1 e
e (xdrx-polyline-make (xdrx-getsamplept e (/ (xd::doc:getpickboxheight) 10.0))
(xdrx-curve-isclosed e)
berase t
(xdrx-entity-matchprop e1 e)
t
(setq dbpl (xdrx-polyline-make))
(setq p1 (getpoint (xdrx-string-multilanguage "\n起始点<退出>:"
"\nStart Point<Exit>:"
(xdrx_pointmonitor "_callback")
(if (xdrx_curve_isclosed e)
(progn (setq pmid (getpoint p1
(xdrx-string-multilanguage "\n中间点<退出>:"
"\nMiddle Point<Exit>:"
(setq pts (append (list p1) (list pmid)))
t
(or (setq p2 (getpoint (if pmid
pmid
p1
(xdrx-string-multilanguage "\n终止点<结束>:"
"\nEnd Point<End>:"
t
(setq p1 (xdrx_curve_getclosestpoint e (trans p1 1 0)))
(setq p2 (xdrx_curve_getclosestpoint e (trans p2 1 0)))
(xdrx-entity-make dbpl)
(xdrx_entity_matchprop e (entlast))
(setq clr (getvar "cecolor")
clr (cond ((= clr "BYLAYER") 256)
((= clr "BYBLOCK") 0)
(T (atoi clr))
(xdrx_setpropertyvalue (entlast)
"constantwidth"
"color" clr
(xdrx-object-release dbpl)
(xdrx_prompt
(xdrx-string-multilanguage "\n局部曲线加粗成功."
"\nLocal curve bolding successful."
(if berase
(xdrx-entity-delete e))
(xdrx_pointmonitor)
(xdrx_end)
