scaled or partially scaled selected objects,
Keep the dimensions, text, and polyline width unchanged
(defun c:XDTB_JBFD (/ e mat mat0 na pj pts scl ss ss1)
(if (not
(setq e (car
(xdrx_entsel (xdrx-string-multilanguage "\n选取边界曲线<手绘>:"
"\nSelect boundary curve <hand drawn>:"
'((0 . "*polyline,circle,ellipse,spline"))
(and (setq p1 (getpoint
(xdrx-string-multilanguage "\n矩形框第一点<退出>:"
"\nFirst point of rectangular box<Exit>:"
(setq p2 (xd::doc:getcorner p1
(xdrx-string-multilanguage "\n第二点<退出>:"
"\nSecond Point<Exit>:"
7
(getvar "ucsxdir")
(setq e (xdrx-polyline-make (cadr p2) t))
(if (and e
(or (xdrx_object_isa e "AcDbCircle")
(xdrx_object_isa e "AcDbEllipse")
(xdrx-curve-isclosed e)
(if (and (setq pts (xdrx_getsamplept e))
(setq ss (ssget "cp" pts))
(progn (ssdel e ss)
(if (> (sslength ss) 0)
(progn (setq pj (xdrx-getpropertyvalue pts "centroid")
mat0 (xdrx_matrix_identity 3)
(setq ss (xdrx_entity_copy ss))
(setq na (strcat "XD_JBFD_" (xdrx_getrandstr)))
(xdrx_block_make na ss pj t)
(apply 'xdrx_insert_clip (cons (entlast) pts))
(setq ss1 (ssadd))
(ssadd (entlast) ss1)
(ssadd e ss1)
(if (and (setq m (xdrx_drag_move (xdrx-string-multilanguage "\n插入点<退出>:"
"\nInsert Point<Exit>:"
ss1
(trans pj 1 0)
(xdrx_entity_transform ss1 m)
(setq m (xdrx_drag_scale (xdrx-string-multilanguage "\n输入或拾取点确定缩放比例:"
"\nEnter or pick points to determine scaling:"
ss1
(trans (xdrx_drag_getlastpoint) 1 0)
(progn (xdrx_entity_transform ss1 m)
(setq mat (xdrx_drag_getlastMatrix)
scl (xdrx_matrix_scalefactor mat)
(XD::Entity:SetOverRide (entlast) scl)
