the software as is would cause you to fail an audit.
Hi Jeff,
Maybe you can expand on this a bit. I’ve also been known to write closed source software, and I’ve also used INNO setup.
To do any government work you will have to obtain
CMMC Cybersecurity Maturity Model CertificationIt will apply to anyone doing any jobs for DOD(Department of Defense).
You have to hire a accredited CMMC Third-Party Assessment Organization to do an assessment and to issue a certificate, and update it yearly. If the they feel like you are not practicing good cybersecurity practices they will not issue a certificate.
Level 1 is required to just get paid, you your going to send them a email or document like a bill you must be certified.
We would be level 2 since we will handle non classified documents, and basically increases the requirements of
NIST SP 800-171Back to level 1 is as simple as if DOD buys material from Home Depot then they must have certificate to get paid.
I am not saying anything wrong with software but if found in a scan you would have to explain why and was just elaborating on some of the points pkohut made.
Bosses would be pissed if we were not able to get paid.
Absolutely nothing against xcad, but more politics than anything,
