(defun c:XDTB_Crv2Wipout (/ dist tmd e box wipeout) (xdrx-begin) (if (and (setq dist (getreal (xdrx-string-multilanguage "\n偏移距离<退出>:" "\nOffset Dist<Exit>:" ) ) ) (setq tmd (getint (xdrx-string-multilanguage "\n输入WipeOut透明度<退出>:" "\nEnter WipeOut transparency <exit>:" ) ) ) (setq e (car (xdrx-entsel (xdrx-string-multilanguage "\n拾取未封闭的多段线<退出>:" "\nPick unclosed polyline<Exit>:" ) '((0 . "*POLYLINE") (-4 . "&=") (70 . 0)) ) ) ) ) (progn (xdrx-setvar "boxclosed" 1) (if (and (setq box (xdrx-getpropertyvalue e "tobox" dist dist 0.0 0.0)) (setq wipeout (xdrx-wipeout-make (xdrx-curve-getsamplepoints box 0.1) ) ) ) (progn (xdrx-setpropertyvalue wipeout "color" 253 "Transparency" tmd) (xdrx-draworder->top wipeout) (xdrx-draworder->top e) (setq grpna (xdrx_group_make "*" e wipeout)) (xdrx-prompt (xdrx-string-multilanguage "\n成功制作WIPEOUT,已建组." "\nWIPEOUT was successfully created and the group has been established." ) ) ) ) ) ) (xdrx-end) (princ))
I'm curious what app you're using to create your gif's. Since Autodesk discontinued their app, we've been looking for a good replacement. So far, the one's I've seen don't have the features you're using that highlight cursor movement and clicks.
Quote from: 57gmc on January 10, 2024, 05:06:27 PMI'm curious what app you're using to create your gif's. Since Autodesk discontinued their app, we've been looking for a good replacement. So far, the one's I've seen don't have the features you're using that highlight cursor movement and clicks.Faststone capture quite good tho!
