Author Topic: REALLY NEED HELP WITH REFERENCE MANAGER  (Read 5129 times)
TJAM51
« Reply #15 on: July 13, 2005, 04:51:59 PM »
Yes...............
pmvliet
« Reply #16 on: July 13, 2005, 05:00:41 PM »
post a drawing up so we can see what's going on. For some reason it isn't saving your changes...
« Reply #17 on: July 13, 2005, 05:54:32 PM »
are xrefs nested?
Amsterdammed
« Reply #18 on: July 16, 2005, 03:03:34 AM »
TJAM51,
We had the same Problem in our Company, server location changed and all the xrefs were gone. We work with R2002.
I  found  there
http://www.intelcad.com/pages/xrepath/
a 30 days trial version I used. It works without opening Acad.
Maybe a solution for the moment………
Bernd
whdjr
« Reply #19 on: July 18, 2005, 10:48:07 AM »
Quote from: Amsterdammed
TJAM51,
I  found  there
Bernd
...but doesn't this just change a 'hard-coded' path to another 'hard-coded' path?
I believe he wanted to set the paths relative.
TJAM51
« Reply #20 on: July 18, 2005, 11:03:49 AM »
I need the paths to be relative...if not as all well knows when we send a cd to the client with all files if all is set to relative then as long as the xrefs are in the same directory then all is well.
tcdan
« Reply #21 on: July 18, 2005, 11:47:41 AM »
Unless you change folders a LOT, you might try using express tools REDIR.  It allows you to change directories from the command line - and I think you can make them relative as well.
Here's AutoDesk's solution for CAD2000
Issue
You want to change absolute xref paths to relative paths in a drawing.
Solution
You can use either of the following methods to change absolute xref paths to relative paths, using AutoCAD® Express Tools software.
Method #1
Use the Express Tools command XPATH:
   1. On the Express menu, click File Tools > Edit Xref Path.
      Alternatively, enter xpath on the command line.
   2. Browse to drawing containing xrefs and click Add.
   3. Select all the xrefs whose paths you want to change.
   4. Enter ..\<drawing path>\ in the Replace With box.
      For example, if the xrefs are in K:\drawings\, enter ..\drawings\ in the Replace With box.
Method #2
Use the Express Tools command REDIR:
   1. On the Express menu, click File Tools > Path Substitution.
      Alternatively, enter redir on the command line.
   2. Specify which attachment types to redirect using the REDIRMODE command.
   3. Select the Xref option and clear the other options.
   4. At the Enter Old Directory prompt, enter the path to be replaced (for example K:\drawings\).
   5. At the Replace <original path> With prompt, enter the relative path you want (for example ..\drawings\).
KewlToyZ
Re: REALLY NEED HELP WITH REFERENCE MANAGER
« Reply #22 on: May 02, 2006, 12:57:09 PM »
I found that XPATH is gone in 2006.
