Author Topic: REALLY NEED HELP WITH REFERENCE MANAGER  (Read 5127 times)
TJAM51
« on: July 13, 2005, 10:36:35 AM »
Reference manager states I can change the x-ref path to relative. I cannot find out how to do this no matter how much reading I do. I am using 2004..........would really appreciate any assistance.....
« Reply #1 on: July 13, 2005, 11:11:17 AM »
This is what I have. I have never used this so I'm not much help.
To change saved reference paths
In the tree view, click a drawing or a reference.
In the Reference list, select one or more references whose saved paths you want to change. You can use CTRL-click or SHIFT-click to make multiple selections in the Reference list.
On the Edit menu, click Edit Selected Paths.
In the Edit Selected Paths dialog box, in New Saved Path, enter the new path name. You can click Browse for Folder to locate a folder.
Click OK.
For the selected references, all path names are changed to the path that you entered in New Saved Path.
David Hall
  • Automatic Duh Generator
« Reply #2 on: July 13, 2005, 11:17:34 AM »
what I did was open the Xref Manager, and type in the relative path I wanted in the Xref Found box.  Then hit save path
TJAM51
« Reply #3 on: July 13, 2005, 11:35:11 AM »
I have tried typing in the path...no luck. I have selected the path through the browser and deleted the path.....no luck. The help section states that if you do this, the directory the drawings are located in is the default directory...no luck.  When I do this, the path is still full path and not relative.
pmvliet
« Reply #4 on: July 13, 2005, 12:24:18 PM »
i believe what you want to do is start reference manager, select your reference file and edit path.
for the path you want to put "..\" "your folder" \ "another folder"
or however your files are in other folders.
so add dot dot slash ..\
pieter
DanB
« Reply #5 on: July 13, 2005, 12:27:08 PM »
You are able to select the Full Path/Relative Path/No Path option when you first attach an external reference file.  Once it is attached I am not sure that you can change this path setting, however you can look into the e-transmit which will remove path settings as an option.
David Hall
« Reply #6 on: July 13, 2005, 12:40:51 PM »
Quote from: DanB
You have to type in the new path or browse to it, and hit save path
TJAM51
« Reply #7 on: July 13, 2005, 01:24:29 PM »
I have done pretty much all that has been stated. We have directories that may have 183 drawings and these drawings are transferred from one directory to another depending upon the status of the job. This is a pretty standard procedure for MEP firms. For some reason I cannot seem to discover what it takes to do what Autocad says it will do...... :cry:
pmvliet
« Reply #8 on: July 13, 2005, 02:18:00 PM »
The method I explained does work for me. Are your paths to your reference files under the initial sheet files?
Cadd (where your sheet files are)
   |-reference location 1
   |-reference location 2
are you swapping between 1 and 2 or outside of this initial tree of folders?
maybe a little more info would help. if this is something that is standard for MEP, what have you done in the past?
Pieter
[/img]
whdjr
« Reply #9 on: July 13, 2005, 02:47:35 PM »
If your using the Reference Manager when it asks you for the new path just leave it blank.
TJAM51
« Reply #10 on: July 13, 2005, 02:57:49 PM »
All the x-ref's are located in the same directory as the sheet files. When we copy to another directory whcih indicates the next stage of design we copy the whole group not leaving anything out.
pmvliet
« Reply #11 on: July 13, 2005, 03:36:47 PM »
So in that case, you want to do what Will said and just strip the reference path. Just leave it blank.
As long as all your files in one folder that will work.
Pieter
TJAM51
« Reply #12 on: July 13, 2005, 03:47:48 PM »
I did that. I stripped the file directgory usning the reference manager and when I went into the drawings the x-ref was still showing to be pathed full.
pmvliet
« Reply #13 on: July 13, 2005, 04:05:51 PM »
when all else fails, post a drawing to the lily pond and let us take a look.
if the paths are indeed stripped, it should work just fine.
Pieter
whdjr
« Reply #14 on: July 13, 2005, 04:34:17 PM »
Quote from: TJAM51
Did you 'apply' the changes before closing the Reference Manager?
