Author Topic: Who knows how to map minutes and degrees and such?  (Read 2423 times)
Dr. After
« on: July 13, 2005, 09:57:04 AM »
I have the following information, but being that I am a steel detailer in America, I never use degrees, minutes, or meters for that matter.  This is a sample of what I am trying to input, but I am having trouble using the correct entry method in CAD 2006:
thence N 62%%C 37' 14" W, 212.38 meters to corner 2;
thence N 29%%C 21' 15" E, 187.02 meters to corner 3;
etc....
so how do I enter thes commands in CAD?  I will supposedly end up with a pentagon of sorts and plan on drawing it up with a pline, so concider that command already active, I just need to know how to enter the direction and length.
Thanks!
David Hall
  • Automatic Duh Generator
« Reply #1 on: July 13, 2005, 10:23:44 AM »
@212.37<N62D37'14"W    hit enter then
@187<N29D21'15"E   and hit enter
David Hall
« Reply #2 on: July 13, 2005, 10:24:35 AM »
First assumption is you have converted your dwg to meters or you are going to convert 212.38 to feet and inches.
Dr. After
« Reply #3 on: July 13, 2005, 10:27:11 AM »
Of course I copnverted it...  I just didn't know the wordage to eneter it.  Thanks!!!
t-bear
« Reply #4 on: July 13, 2005, 12:59:00 PM »
Dr. After.......welcome to the "Swamp".
DA said:
We learned long ago not to take too much for granite.......... :roll:
Glad it helped.
Dr. After
« Reply #5 on: July 13, 2005, 03:13:38 PM »
Quote from: t-bear
Glad it helped.
 :wink:
Graldensblud
« Reply #6 on: July 19, 2005, 04:54:21 PM »
I'm curious as to why a designer is specifying steel angles in minutes and seconds. Are they trying to be awkward or just naturally talented ;)
I mean, come on, its only geographers that use minutes and seconds of arc these days (though i remember converting all my answers in a maths exam into them when i was bored... just to annoy the examiner)
CADaver
« Reply #7 on: July 19, 2005, 05:13:04 PM »
The way I read it was he's a detailer and NOT used to these kinds of inputs, meaning he's doing something else.  From his post I'm guessing it's a property plat of some kind that has the property description in Surveyor's terms.
« Reply #8 on: July 19, 2005, 06:16:27 PM »
Quote from: CADaver
Agree but meters (for you brits metre *grin*)!! That one through me for a loop.
MikePerry
« Reply #9 on: July 19, 2005, 08:03:15 PM »
Quote from: Mark Thomas
Thank you, Mark :)
adjusting score card ;-)
Dent Cermak
« Reply #10 on: July 19, 2005, 08:36:51 PM »
must work for the government.CofE and most DOT's still insist that metric is not dead. I still have to do the meter thing about every 10th project.
CADaver
« Reply #11 on: July 19, 2005, 08:51:36 PM »
Quote from: Dent Cermak
must work for the government.CofE and most DOT's still insist that metric is not dead..
or doing something somewhere besides the US.  I currently have a Chilian job on deck that uses meters for surveyors units, and we see descriptions just like those.
Graldensblud
« Reply #12 on: July 20, 2005, 02:55:58 AM »
Metres are easy, but then i would say that wouldn't i - uk's been metric  since before i was born. You just don't often see metres and non-decimal degrees mixed (at least not on our side of the pond ;)
Dr. After
Re: Who knows how to map minutes and degrees and such?
« Reply #13 on: September 08, 2005, 03:42:22 PM »
I didn't mean to leave you guys hanging.  Shoot I didn't even know you guys were trying to piece this together.  In any case, I was transposing a lot that my wife and I own in Saipan onto a map of the Island.
