(defun c:XDTB_Ncopy (/ blkref mat p1 p2 box ss ents) (xdrx-begin) (if (and (setq blkref (car (xdrx-entsel (xdrx-string-multilanguage "\n拾取图块或XREF<退出>:" "\nPick BLOCK or XREF<Exit>:" ) '((0 . "insert")) ) ) ) (setq mat (xdrx-matrix-wcs2block blkref)) (setq p1 (getpoint (xdrx-string-multilanguage "\n窗口第一点<退出>:" "\nFirst point of window <Exit>:" ) ) ) (setq p2 (xd::doc:getcorner p1 (xdrx-string-multilanguage "\n窗口第二点<退出>:" "\nSecond point of window <Exit>:" ) 7 nil ) ) (setq box (last p2)) (setq ss (xdrx-block-getentities blkref "wp" box));;BLOCK, XREF, window selection entities (setq ms (xdrx-get-currentspace));;Current Space ID (setq ents (xdrx-object-deepclone ms ss mat)) ;;Deep clone from XREF database to current space, apply transformation matrix, clone in situ ) (progn (xd::drag:freemove ents (xd::geom:get9pt ents 5);drag basepoint at center (+ 1 4 128);;Activate the base point, rotate 90 degrees, and align 547 t ) ) ) (xdrx-end) (princ))
I got this: Command: XDTB_NCOPYPick BLOCK or XREF<Exit>:First point of window <Exit>:Second point of window <Exit>:Application Error: 0 :- no function definition: nilno function definition: nil
