Author Topic: Why/How does re-restarting a command produce: "Unknown command"?  (Read 1205 times)
ScottMC
Please consider:
(defun c:ffr (/ *error* asel adata) ;; https://www.theswamp.org/index.php?topic=56774.msg604922#msg604922
  ;;; Kent Cooper, 8 October 2019
        (setvar 'cmdecho 0)
      (defun *error* ( msg )
        (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
        (if qaf (setvar 'qaflags qaf))
        (if msg (prompt msg))
            (setvar 'cmdecho 1)
  (vla-startundomark
    (setq doc (vla-get-activedocument (vlax-get-acad-object)))
    (command "fillet" "r" (getdist (strcat "\n Radius: "(rtos (getvar 'filletrad) 3 5)"\n Enter/Pick Fillet Radius: " )))
    (princ (strcat "\n ** Radius Now: "(rtos (getvar 'filletrad) 3 5)" **"))
 (while                                               ;; fillet loop
           (princ " ") ;; enables loop.. ??????
  (setvar 'cmdecho 1)
 (command "_.fillet" "\\" "\\")
 );; end of while
 (setvar 'cmdecho 1)
  (*error* nil)
BIGAL
  • 40 + years of using Autocad
Re: Why/How does re-restarting a command produce: "Unknown command"?
« Reply #1 on: August 22, 2023, 09:35:08 PM »
Maybe ask Kent he is on the Autodesk forum all the time, yes locked up my Bricscad when ran a second time.
ScottMC
« Reply #2 on: August 22, 2023, 09:44:24 PM »
Found Kents working program.. sorry I didn't sooner.
        (setvar 'cmdecho 0)
            (setvar 'cmdecho 1)
  (vla-startundomark
  (setvar 'cmdecho 1)
 );; end of while
 (setvar 'cmdecho 1)
  (*error* nil)
