I've mod. CAB's Break Objects routine to suit my needs... Perhaps it'll work with your examples... Test it if you have a time...You should use : (c:BreakAll-nogap)
Quote from: ribarm on June 10, 2023, 11:47:13 AMI've mod. CAB's Break Objects routine to suit my needs... Perhaps it'll work with your examples... Test it if you have a time...You should use : (c:BreakAll-nogap)many thanks my idea is while I am drawing a line,it breaks any objects it crossed。Not to select line I have drawed and other objrcts。
you misunderstand me,CAB code is perfect,just I cant mod it for my useps CIRCLE can be break(360 degree) with line if use breakall lisp,>> . . . . .
