Hi john,
where can I find the 2.3 version and how or where do I learn what's new in the new version... I'm intrigued to know ![smiley :-)](https://www.theswamp.org/Smileys/black/smiley.gif)
Many Thanks.
Matt
@mmccormack
I can show you how to comment out a line of code in AutoLisp but I cannot show you how to search the forum.
In AutoLisp you can "comment out" a line by adding a Semicolon in front of it.
Example:
"Variable2" is commented out.
To do this, open the lisp file in a "Text Editor" to make the change. I use an editor called "VIM", some use "VS Code", "Notepad+", "UltraEdit", "Crimson", "Atom" (these are all programs you should be googling/trying/etc if you wish to write programs). liuhe gave you one of the lines to comment out, the other is towards the top of the file and is about a "Fill color".
@liuhe
I thought instead changing the color, you could just make the hatch transparent like (and not need those two lines):
(vl-cmdf "-hatch" "T" 77 "P" patternName "S" newpline3 "" "")
Again, nice addition to the routine. Thank you.
