The MD5 algorithm of the lsp version is very slow, which is criticized by many people. Can you optimize it and improve the speed?
Yc-MD5.lsp is the source code of MD5 algorithm for lsp version found in the forum. It has been changed from time to time with little speed improvement. It seems that we need to find another way out.
For optimize the code source.lisp, then you must learn, before, other programming language. (e.g Java, Julia, ). Why?
Because .. The module javac.exe contain hunders * hunders of optimizations.
Too many years, 10-50 engineers work at
--a)code optimization of speed
--b)code optimization of eating memory
--c)code optimization of parse the variabile (local, static ,global , dynamical, incapsulate inside Object)
Ps:=Visual Lisp are too weak for support the optimizations.
![sleezy :sleezy:](https://www.theswamp.org/Smileys/black/sleezy.gif)
