I'm testing the new AutoCAD 2023 for porting my applications.
It seems that something has changed or that there is a bug.
In fact, if I insert a LISP (eg test.lsp) in the Startup Suite of the APPLOAD command, this is not automatically executed during the startup of AutoCAD 2023.
I tried to add the folder path among the trusted paths and check the SECURELOAD variable, but all to no avail
![cry :cry:](https://www.theswamp.org/Smileys/black/cry.gif)
The same procedure works correctly with previous versions of AutoCAD.
Do you also have this problem?
Is there any solution?
Thanks!
