I'm testing the new AutoCAD 2023 for porting my applications.
It seems that something has changed or that there is a bug.
In fact, if I insert a LISP (eg test.lsp) in the Startup Suite of the APPLOAD command, this is not automatically executed during the startup of AutoCAD 2023.
I tried to add the folder path among the trusted paths and check the SECURELOAD variable, but all to no avail
The same procedure works correctly with previous versions of AutoCAD.
Do you also have this problem?
Is there any solution?
Thanks!
