Author Topic: Convert String to Number  (Read 511 times)
cmwade77
« on: March 25, 2022, 02:26:39 PM »
Here is the challenger, convert any string into a number, this could be simple strings like:
"100"
"100.45"
or more complex strings like:
"THIS IS A TEST 100 TEST"
For the last example, the value should return 100.
Additionally, all MText and other formatting should be ignored.
Here is my entry:
  (defun Str2Num (Str / List_Check List_Numbers List_Characters Results Character)
    ;Supporting Functions
    (defun LM:UnFormat ( str mtx / _replace rx )
      ;;-------------------=={ UnFormat String }==------------------;;
      ;;  Returns a string with all MText formatting codes removed. ;;
      ;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
      ;;  Arguments:                                                ;;
      ;;  str - String to Process                                   ;;
      ;;  mtx - MText Flag (T if string is for use in MText)        ;;
      ;;  Returns:  String with formatting codes removed            ;;
      (defun _replace ( new old str )
        (vlax-put-property rx 'pattern old)
        (vlax-invoke rx 'replace str new)
      (if (setq rx (vlax-get-or-create-object "VBScript.RegExp"))
          (setq str
            (vl-catch-all-apply
              (function
                (lambda ( )
                  (vlax-put-property rx 'global     actrue)
                  (vlax-put-property rx 'multiline  actrue)
                  (vlax-put-property rx 'ignorecase acfalse)
                  (foreach pair
                      ("\032"    . "\\\\\\\\")
                      (" "       . "\\\\P|\\n|\\t")
                      ("$1"      . "\\\\(\\\\[ACcFfHLlOopQTW])|\\\\[ACcFfHLlOopQTW][^\\\\;]*;|\\\\[ACcFfHLlOopQTW]")
                      ("$1$2/$3" . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);")
                      ("$1$2"    . "\\\\(\\\\S)|[\\\\](})|}")
                      ("$1"      . "[\\\\]({)|{")
                    (setq str (_replace (car pair) (cdr pair) str))
                  (if mtx
                    (_replace "\\\\" "\032" (_replace "\\$1$2$3" "(\\\\[ACcFfHLlOoPpQSTW])|({)|(})" str))
                    (_replace "\\"   "\032" str)
          (vlax-release-object rx)
          (if (null (vl-catch-all-error-p str))
            str
    ;End Supporting Functions
    (setq Str (LM:Unformat Str T))
    (setq List_Check (list 45 46 48 49 50 51 52 53 54 55 56 57)
          List_Characters (vl-string->list Str)
    (foreach Character List_Characters
      (if (member Character List_Check)
        (setq List_Numbers (cons Character List_Numbers))
        (setq List_Numbers (cons 32 List_Numbers))
    (setq Results (vl-string-trim " " (vl-list->string (reverse List_Numbers))))
    (if (= (substr Results 1 1) ".")
      (setq Results (strcat "0" Results))
    (read Results)
Re: Convert String to Number
« Reply #1 on: March 25, 2022, 03:50:03 PM »
This is very similar to one of our challenges already (String index).
https://www.theswamp.org/index.php?topic=57413.0
cmwade77
« Reply #2 on: March 25, 2022, 05:50:27 PM »
Similar, but I would say a little different, as the indexer in the challenge doesn't necessarily account for mtext formatting and it doesn't actually return the value of the number as near as I can tell.
This one should output just the number from the text.
« Reply #3 on: March 25, 2022, 07:20:03 PM »
Ok.
No it doesn't return the actual substring but if you have the indexes then getting the substring is trivial.
Although, I think you may not want people to submit other people's code (even if they are only meant as utilities) because that's a little unfair to the original author and not really teaching you or anyone else anything if you just use their process.
cmwade77
« Reply #4 on: March 25, 2022, 07:57:22 PM »
I think you may be right there, I will modify it when I have the chance.
« Last Edit: March 28, 2022, 11:31:04 AM by cmwade77 »
