Author Topic: remove the unnecessary vertices  (Read 3769 times)
domenicomaria
« on: March 17, 2022, 04:09:01 PM »
  1. (defun :LWP-EMK-V-LST   (v-lst)
  2.    (entmake
  3.       (append
  4.             (list   '(0 . "LWPOLYLINE")   '(100 . "AcDbEntity")   '(100 . "AcDbPolyline")   (cons 90 (length v-lst) ) )
  5.             (apply 'append    (mapcar '(lambda (i) (list (cons 10 i ) ) )  v-lst) )
  6.       )
  7.    )
  8. )
  9.
  10. (defun :LST-LAST-1 ( l / l-len) (if (> 1 (- (setq l-len (length l) ) 1) )   nil  (nth (- (- l-len 1) 1) l) ) )
  11.
  12. ;   v-lst   CANNOT CONTAIN consecutive coincident points (no ZERO LENGTH SEGMENTS)
  13. (defun :GEOM-V-LST-REMOVE-ALIGNED-VERTICES (v-lst ang-fuzz /  ang23 p1 p2 p3 prev-ang r)
  14.    ;   (setq v-lst   (vl-list* (:lst-last-1 v-lst) v-lst) )
  15.
  16.    (setq p1    (car  v-lst)     p2          (cadr v-lst)
  17.          r     (list p1 p2)    prev-ang    (angle p1 p2)
  18.          v-lst (cdr  v-lst)
  19.    )
  20.    (while (cdr v-lst)
  21.       (setq p2 (car v-lst)   p3 (cadr v-lst)     ang23 (angle p2 p3)   )
  22.       (if(equal prev-ang ang23 ang-fuzz)
  23.          (setq r (cons p3 (cdr r) ) )
  24.          (setq r (cons p3 r) )
  25.       )
  26.
  27.       (setq v-lst (cdr  v-lst) prev-ang ang23)
  28.    )
  29.    (reverse r)
  30. )
  31.
  32.
  33.
  34.
  35.
  36. (defun c:test ( / r v-lst )
  37.    (setq v-lst '((1285.09 272.024 0.0) (1328.19 291.889 0.0) (1371.1 311.668 0.0) (1431.08 339.319 0.0) (1481.62 362.613 0.0) (1463.51 377.038 0.0) (1439.14 396.446 0.0) (1420.56 411.244 0.0) (1392.12 393.476 0.0) (1375.22 382.92 0.0) (1359.5 373.102 0.0) (1351.87 413.152 0.0) (1393.13 428.569 0.0) (1410.92 435.215 0.0) (1453.95 451.294 0.0) (1411.03 470.398 0.0) (1373.22 487.227 0.0) (1331.84 505.647 0.0) (1298.95 481.425 0.0) (1258.69 451.775 0.0) (1223.08 425.548 0.0) (1248.95 361.498 0.0) (1259.27 335.942 0.0) (1268.89 312.131 0.0) (1285.09 272.024 0.0) ) )
  38.    (setvar "cecolor" "70") (:LWP-EMK-V-LST v-lst)
  39.    (setq r (:GEOM-V-LST-REMOVE-ALIGNED-VERTICES v-lst 0.0174533) )
  40.    (setvar "cecolor" "222") (:LWP-EMK-V-LST r)
  41. )
I have a list of counterclockwise points
If I draw them, I can see that there are some unnecessary vertices that are aligned and between other "main" vertices
I want to remove the unnecessary vertices, leaving only the main vertices
but something goes wrong
and I can't figure out what
« Last Edit: March 17, 2022, 04:52:25 PM by domenicomaria »
tombu
  • ByLayer=>Not0
Re: remove the unnecessary vertices
« Reply #1 on: March 17, 2022, 06:08:22 PM »
(strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\Overkill")returns the location of all saved options for the OVERKILL command.
I'd save the existing settings like
(vl-registry-read registry "OptimizePolylines")and reset them like
(vl-registry-write registry "OptimizePolylines" "1")run the OVERKILL command using command-s then reset the previous settings.
It's a powerful command but pain to simply run at the command line because there's so many settings and they're all stored in the registry.
Tom Beauford P.S.M.
domenicomaria
« Reply #2 on: March 18, 2022, 12:38:47 AM »
I need a math and geometry solution ...
... not a command to use for a polyline
anyway OVERKILL is great !
« Last Edit: March 18, 2022, 03:36:10 AM by domenicomaria »
domenicomaria
« Reply #3 on: March 18, 2022, 03:13:52 AM »
         v-lst (cdr  v-lst)
The red code is wrong.
It must be : (setq r (list p2 p1) )
Anyway, it works better, but sometimes, it does not remove 1 unnecessary vertex . . .
I've also tried to modify ang-fuzz,
but still sometimes it doesn't remove an unnecessary vertex
« Last Edit: March 18, 2022, 03:34:59 AM by domenicomaria »
domenicomaria
« Reply #4 on: March 18, 2022, 07:12:10 AM »
  1. (defun :LST-REVERSE-CDR (l) (reverse (cdr (reverse l) ) ) )
  2.
  3. (defun :GEOM-V-LST-REMOVE-ALIGNED-VERTICES (v-lst ang-fuzz /  ang23 p1 p2 p3 prev-ang first-ang r)
  4.    (setq p1    (car  v-lst)     p2         (cadr  v-lst )
  5.          r     (list p2 p1)    prev-ang    (angle p1 p2 )   first-ang prev-ang
  6.          v-lst (cdr  v-lst)
  7.    )
  8.    (while (and (setq p2 (car v-lst) ) (setq p3 (cadr v-lst) ) )
  9.       (setq ang23 (angle p2 p3) )
  10.       (if(equal prev-ang ang23 ang-fuzz)
  11.          (setq r (cons p3 (cdr r) ) )
  12.          (setq r (cons p3 r) )
  13.       )
  14.       (setq v-lst (cdr  v-lst) prev-ang ang23)
  15.    )
  16.    (if (equal prev-ang first-ang ang-fuzz)  (setq r (cdr (:LST-REVERSE-CDR r) ) ) )
  17.    (reverse r)
  18. )
. . . while this one seems to work well !
« Last Edit: March 18, 2022, 10:03:08 AM by domenicomaria »
kirby
« Reply #5 on: March 18, 2022, 10:08:31 AM »
Another approach using Douglas-Puecker algorithm, which reduces excess vertices based on a corridor width.  Originally found on Compuserve message board as 'Polyweed.lsp' with no author listed.  I've been using it for 30+ years to reduce digitized polylines, recently refactored it and added a trial mode to test various corridor widths.  My application was waterway/streamline polyline reduction on large rural drainage project, reducing 1000's of bloated polylines and converting them into a hydraulic (SWMM) model.
However, does not handle polyarc segments since most digitizing (or imported shapefiles) only have line segment polylines.
Uses a lot of library routines (and long code...that's just my approach, all added to the included file from libraries).
Really good description here:
https://cartography-playground.gitlab.io/playgrounds/douglas-peucker-algorithm/
Also known as Ramer-Douglas-Peucker
https://en.wikipedia.org/wiki/Ramer%E2%80%93Douglas%E2%80%93Peucker_algorithm
Core routine:
  1. (defun DouglasPeucker (PointList IsClosed CorridorWidth /
  2.                 OutList BPT BP1 BP2 LPT CNT1
  3.                 )
  4. ; Polyline vertex reduction by Douglas-Peucker method
  5. ; c. 1992, Refactored KJM - March 2019
  6. ; Uses classic Douglas-Peucker algorithm 1973
  7. ;       https://utpjournals.press/doi/10.3138/FM57-6770-U75U-7727
  8. ; Input:
  9. ;       PointList - (list) list of points (vertices of straight segment polyline)
  10. ;       IsClosed - (integer) 0 or nil if polyline is open, 1 if polyline is closed
  11. ;       CorridorWidth - (real) width of corridor centred on polyline
  12. ;       future addition: StepMode - (integer) 0 or nil = run automatically, 1 = step through and wait for user feedback
  13. ; Returns:
  14. ;       list of weeded points
  15. ; Uses custom functions
  16. ;       perdist
  17.
  18. (setq OutList nil)
  19.
  20. (if PointList
  21.   (progn
  22.         (if (eq (type PointList) 'LIST)
  23.           (progn
  24.
  25.                 ; Look at each point in the list
  26.                 (setq BPT (nth 0 PointList))
  27.                 (setq BP1 (nth 1 PointList))
  28.                 (setq BP2 (nth 2 PointList))
  29.                 (setq LPT BP1)
  30.
  31.                 (setq OutList (cons BPT OutList))
  32.
  33.                 (setq CNT1 2)
  34.                 (while (nth CNT1 PointList) ;step through list
  35.                         ;(prompt "\n CNT1 = ")(princ CNT1)
  36.
  37.                         (cond
  38.                                 ((<= (perdist BPT BP1 BP2)  (* 0.5 CorridorWidth))      ;find point where cooridor width exceeded
  39.                                   (progn
  40.                                         (setq LPT BP2)
  41.                                         (setq BP2 (nth (1+ CNT1) PointList))
  42.                                         ; (setq weedpts (1+ weedpts))
  43.                                   )
  44.                                 )
  45.
  46.                                 (T              ;BP2 outside of distance
  47.                                   (progn
  48.                                         (setq OutList (cons LPT OutList))
  49.                                         (setq BPT LPT)
  50.                                         (setq BP1 BP2)
  51.                                         (setq BP2 (nth (1+ CNT1) PointList))
  52.                                         (setq LPT BP1)
  53.                                   )
  54.                                 )
  55.                         ) ; close cond
  56.
  57.                         (setq CNT1 (1+ CNT1))
  58.                 ) ; close while
  59.
  60.                 (setq OutList (cons (last PointList) OutList))
  61.                 (setq OutList (reverse OutList))
  62.           )
  63.         ) ; close if
  64.   )
  65. ) ; close if
  66.
  67. OutList
  68. )
  69.
  70.
  71. (defun PerDist (pt1 pt2 pt3 / d1 ang1 ang2 delta)
  72. ; Compute perpendiculat distance
  73. ; c. 1992 author unknown, Mod KJM 1994
  74. ; Input:
  75. ;       p1t, pt2 - (points) two points specifying a ling segment
  76. ;       pt3 - (point) another point
  77. ; Returns:
  78. ;       perpendicular distance from pt3 to line segment pt1-pt2
  79.    (setq d1 (distance pt1 pt3)
  80.          ang1 (angle pt1 pt2)
  81.          ang2 (angle pt1 pt3)
  82.          ang1 (if (> ang2 ang1)(+ ang1 (* pi 2.0)) ang1)
  83.          delta (- ang1 ang2)
  84.   )
  85.   (abs (* d1 (sin delta)))
  86. )
  87.
  88.
domenicomaria
« Reply #6 on: March 18, 2022, 10:52:56 AM »
thank you kirby
It seems to be interesting
I'll take a look at it later
ciao
domenicomaria
« Reply #8 on: March 21, 2022, 11:30:11 AM »
Domenico, hai provato questo: http://www.theswamp.org/index.php?topic=19865.msg244892#msg244892
purge-pline is certainly a great routine. . .
We know that Gile is a guru!
(but you also don't joke) . . .
. . . maybe it is very similar to the OVERKILL command ?
However,
I am not interested in processing the data of a polyline,
but processing the data of a list of points. . .
And anyway, this latest version that I am attaching
seems to work well!
If someone finds me a situation where it doesn't work,
I will be happy to try to improve it.
Ciao
  1. ; for a COUNTER-CLOCKWISE list of points, WITHOUT COINCIDENT POINTS (NO ZERO LENGTH SEGMENTS)
  2. (defun :GEOM-V-LST-REMOVE-ALIGNED-VERTEXES (v-lst ang-fuzz /  ang23 p1 p2 p3 prev-ang first-ang closed r)
  3.    (setq closed (equal (car v-lst) (last v-lst) 1e-9) )
  4.
  5.    (setq p1    (car  v-lst)    p2          (cadr  v-lst )
  6.          r     (list p2 p1)    prev-ang    (angle p1 p2 )   first-ang prev-ang
  7.          v-lst (cdr  v-lst)
  8.    )
  9.    (while (and (setq p2 (car v-lst) ) (setq p3 (cadr v-lst) ) )
  10.       (setq ang23 (angle p2 p3) )
  11.       (if(equal prev-ang ang23 ang-fuzz)
  12.          (setq r (cons p3 (cdr r) ) )
  13.          (setq r (cons p3 r) )
  14.       )
  15.       (setq v-lst (cdr  v-lst) prev-ang ang23)
  16.    )
  17.
  18.    (if closed
  19.       (if(equal prev-ang first-ang ang-fuzz)
  20.          (setq r (cdr (reverse (cdr (reverse r) ) ) ) )
  21.       )
  22.    )
  23.
  24.    (if closed (setq r (append r (list (car r) ) ) ) )
  25.
  26.    (reverse r)
  27. )
  28.
this is the latest working version !
VovKa
  • Ukraine
« Reply #9 on: March 21, 2022, 12:05:34 PM »
(setq v-lst '((1192.63 291.385) (1208.37 301.527) (1224.28 311.405) (1240.35 321.018) (1256.58 330.362) (1272.96 339.434) (1289.49 348.233) (1306.16 356.756) (1322.97 365.0) (1339.92 372.964) (1357.0 380.644) (1374.2 388.039) (1391.52 395.148) (1408.96 401.967) (1426.51 408.495) (1444.17 414.73) (1461.93 420.67) (1479.78 426.315) (1497.73 431.661) (1515.76 436.709) (1533.87 441.456) (1552.06 445.9) (1570.32 450.042) (1588.65 453.879) (1607.04 457.411) (1625.49 460.637) (1643.98 463.555) (1662.53 466.165) (1681.11 468.467) (1699.73 470.459) (1718.38 472.141)))
(while (and (setq p2 (car v-lst)) (setq p3 (cadr v-lst)))
    (setq ang23 (angle p2 p3))
    (if (equal prev-ang ang23 ang-fuzz)
      (setq r (cons p3 (cdr r)))
      (setq r (cons p3 r)
    prev-ang ang23 ;fix
    (setq v-lst (cdr v-lst))
domenicomaria
« Reply #10 on: March 21, 2022, 12:29:18 PM »
VovKa my brain is a little burned. . . :lol:
... be clearer ...
to do a test, I draw a polyline made of only segments,
where many consecutive segments have the same angle ...
... then I extract all the vertices and pass them to my function ...
and then I draw the new polyline that does not contain consecutive aligned segments ...
and it seems to me that it works fine!
The list of points you sent me is made up
of many segments that differ by a very small angle
... just adjust the ang-fuzz value ...
I know you never talk nonsense. . . but help me to understand better, please.
« Last Edit: March 21, 2022, 12:35:57 PM by domenicomaria »
domenicomaria
« Last Edit: March 22, 2022, 12:57:43 AM by domenicomaria »
VovKa
  • Ukraine
« Reply #12 on: March 21, 2022, 03:03:20 PM »
https://imgur.com/a/elMb6Zt
yours to the left, mine to the rigth
i used your fuzz, which i quite small = 1 degree
i believe that this fuzz will be hardcoded in your function and it will not be convenient to change it for every other polygon
the problem with your code is that you compare angles between nonexistent (removed) points
domenicomaria
« Reply #13 on: March 22, 2022, 01:23:12 AM »
  1. (defun :GEOM-V-LST-REMOVE-ALIGNED-VERTEXES (v-lst ang-fuzz /  ang23 p1 p2 p3 prev-ang first-ang closed r)
  2.    (setq closed (equal (car v-lst) (last v-lst) 1e-9) )
  3.
  5.          r     (list p2 p1)    first-ang    (angle p1 p2 )   prev-ang first-ang
  7.    )
  13.       )
  15.             prev-ang (angle (cadr r) (car r) ) ;   fixed
  16.       )
  17.    )
  18.
  19.    (if closed
  20.       (if(equal prev-ang first-ang ang-fuzz)
  21.          (setq r (cdr (reverse (cdr (reverse r) ) ) ) )
  22.       )
  23.    )
  24.
  25.    (if closed (setq r (append r (list (car r) ) ) ) )
  26.
  27.    (reverse r)
  28. )
  29.
  30.
  31.
  32. (defun :LWP-EMK-V-LST   (v-lst)
  33.    (entmake
  34.       (append
  35.             (list   '(0 . "LWPOLYLINE")   '(100 . "AcDbEntity")   '(100 . "AcDbPolyline")   (cons 90 (length v-lst) ) )
  36.             (apply 'append    (mapcar '(lambda (i) (list (cons 10 i ) ) )  v-lst) )
  37.       )
  38.    )
  39. )
  40.
  41. (defun c:TEST ( / r v-lst )
  42.    (setq v-lst '((1192.63 291.385) (1208.37 301.527) (1224.28 311.405) (1240.35 321.018) (1256.58 330.362) (1272.96 339.434) (1289.49 348.233) (1306.16 356.756) (1322.97 365.0) (1339.92 372.964) (1357.0 380.644) (1374.2 388.039) (1391.52 395.148) (1408.96 401.967) (1426.51 408.495) (1444.17 414.73) (1461.93 420.67) (1479.78 426.315) (1497.73 431.661) (1515.76 436.709) (1533.87 441.456) (1552.06 445.9) (1570.32 450.042) (1588.65 453.879) (1607.04 457.411) (1625.49 460.637) (1643.98 463.555) (1662.53 466.165) (1681.11 468.467) (1699.73 470.459) (1718.38 472.141)))
  43.    (setvar "cecolor" "70") (:LWP-EMK-V-LST v-lst)
  44.    (setq r (:GEOM-V-LST-REMOVE-ALIGNED-VERTEXES v-lst 0.017) )
  45.    ;   (:point (car r) )
  46.    (setvar "cecolor" "150") (:LWP-EMK-V-LST r)
  47. )
ok VovKa !
Thank you.
This one seems to work well !
Let me know, please.
Ciao
VovKa
  • Ukraine
« Reply #14 on: March 22, 2022, 07:53:45 AM »
i see that your fix is different from my proposal in https://www.theswamp.org/index.php?topic=57443.msg609304#msg609304
nevertheless it does its job :)
