Author Topic: Completely clear all running commands  (Read 1608 times)
hmspe
« on: March 15, 2022, 04:15:23 PM »
I'm looking for a way to completely clear the LISP engine state so that there is no active LASTPOINT or other carryover from the last command run.  The intent is to have the LISP engine in the same state as it would be in a fresh instance which had had no commands run.
I'm mostly having a problem with the Move command, which I call from a toolbar using the macro   ^C^C^C_MOVE  .  If there was a previous command run most of the time the first attempt to move entities has the entities relocate to a seemingly arbitrary location far away.  After the first attempt the MOVE command works properly.  I'm running latest Bricscad.  I suspect this has to do with Displacement being the default at the "Enter base point [Displacement]" prompt.  I've tried wrapping the move command in LISP so that (COMMAND) is run several times before move is called.  That doesn't help.
Thanks in advance for any suggestions.
BIGAL
  • 40 + years of using Autocad
Re: Completely clear all running commands
« Reply #1 on: March 15, 2022, 08:26:56 PM »
I use Bricscad and no problems but V20 looking at getting v22. In a lisp just sequence, select objects, pt1, pt2.
d2010
« Reply #2 on: March 17, 2022, 01:45:49 PM »
Please you  test two commands, with Osnap=off and Osnap=on
a)(defun dfn_cmd_cancel( / rr cx dx ch)
b)(defun dfn_cmd_canceld( / $rr cx dx ch)
 (setq;|a000|;
ch (quote INT)
cx (jc_cws12 51 9)
dx (getvar cx)
dx (if (/= (type dx) ch) 0 (boole 1  dx 1))) (progn (while (>  dx 0) (setq;|a000|;
dx (getvar cx)
dx (boole 1  dx 1)) (setq;|a17361304|;
$rr (command "")))) (setq;|a13625|;
$rr (getvar (jc_cws12 60 8))) (terpri)
$rr)
« Reply #3 on: March 17, 2022, 02:30:07 PM »
I'm sorry but that code does not make any sense.
This should cancel any active command.
  1. (defun cmd_cancel () (command) (command) (princ))
baitang36
« Reply #4 on: March 17, 2022, 08:13:57 PM »
try this inip.fas
(load "d:/inip.fas")
hmspe
« Reply #5 on: April 15, 2022, 12:56:10 PM »
Thanks for the replies.
@John - That's one of the first things I tried.  The ^C^C^C in the macro should do the same thing, but I also tried calling lisp functions that ran either
  1.   (while (< 0 (getvar "cmdactive")) (command))
  2.
or that called
several times before calling the MOVE command.  Neither fixed the problem.  This seems to be associated with the
  1. Enter base point [Displacement] <Displacement>:
prompt that comes right after selecting entities to move.  Could be that my muscle memory is slipping, or it could be that there's key bounce or something in Bricscad that gets out of sync.  I'll try coding around the default.
@batang36 - Thanks.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #6 on: April 15, 2022, 06:22:17 PM »
try this inip.fas
Hi baitang36
Could you please post your solution in it's .lsp source , not as .fas
Regards,
Called Kerry in my other life
I live at UTC + 13.00
roy_043
  • BricsCAD 18
« Reply #7 on: April 17, 2022, 02:42:43 AM »
Try using:
(command nil)
« Reply #8 on: April 17, 2022, 04:01:25 AM »
LASTPOINT is a system variable, it’s not stored in the lisp engine, but globally for all languages … right?
maybe extend your macro to reset it before calling move?
« Last Edit: April 17, 2022, 04:05:41 AM by It's Alive! »
baitang36
« Reply #9 on: April 17, 2022, 07:11:07 AM »
try this inip.fas
Hi baitang36
Regards,
source is simple
(init:AUTOLISP-package)
But you can't run it. Because this function is a reserved function that is not written to the public document. It can only be used in FAS, not in LSP.
This function can restore all system functions to the original state. For example, if you redefine a system function, such as print, your definition will be invalidated after executing this function
« Last Edit: April 17, 2022, 07:19:17 AM by baitang36 »
