Author Topic: [challenge] A31 : Midverse  (Read 1448 times)
« on: March 07, 2022, 11:12:19 AM »
Reverse the middle letters of a word.
Write a procedure `midverse` that reverses all but the first and last letters of a word.
For example:
(midverse "retinues")
should return "reunites".
Check that
(midverse (midverse [word]))
leaves the word unchanged.
gile
  • Marseille, France
Re: [challenge] A31 : Midverse
« Reply #1 on: March 07, 2022, 11:31:24 AM »
  1. (defun midverse (s)
  2.   (vl-list->string
  3.     ((lambda (l)
  4.        (append (cons (car l) (cdr (reverse (cdr l)))) (list (last l)))
  5.      )
  6.       (vl-string->list s)
  7.     )
  8.   )
  9. )
Marc'Antonio Alessi
  • Marco
« Reply #2 on: March 07, 2022, 11:36:19 AM »
...finito... (end) or is with Vanilla Lisp?
« Reply #3 on: March 07, 2022, 11:39:38 AM »
  1. (defun midverse-rjp (str / a b c)
  2.   (setq a (vl-string->list str))
  3.   (setq b (car a))
  4.   (setq c (last a))
  5.   (setq a (cdr a))
  6.   (vl-list->string (append (list b) (cdr (reverse a)) (list c)))
  7. )
  8. (midverse-rjp "retinues")
Probably slow...
Non VL
  1. (defun midverse-rjp2 (str / n r)
  2.   (setq n 1)
  3.   (repeat (- (strlen str) 2) (setq r (cons (substr str (setq n (1+ n)) 1) r)))
  4.   (strcat (substr str 1 1) (apply 'strcat r) (substr str (strlen str) 1))
  5. )
  6. (midverse-rjp2 "retinues")
« Last Edit: March 07, 2022, 11:45:51 PM by ronjonp »
Windows 11 x64 - AutoCAD /C3D 2022
gile
  • Marseille, France
« Reply #4 on: March 07, 2022, 11:41:20 AM »
Without vl* functions:
  1. (defun midverse (s / str->list)
  2.   (defun str->list (s)
  3.     (if (< 0 (strlen s)) (cons (ascii (substr s 1 1)) (str->list (substr s 2))))
  4.   )
  5.          (mapcar 'chr
  6.                  ((lambda (l)
  7.                     (append (cons (car l) (cdr (reverse (cdr l)))) (list (last l)))
  8.                   )
  9.                    (str->list s)
  10.                  )
  11.          )
  12.   )
  13. )
« Last Edit: March 07, 2022, 11:58:56 AM by gile »
« Reply #5 on: March 07, 2022, 11:46:01 AM »
Mine (without vl):
It looks like I had the same idea as gile (that's a big bump to my ego for the day!).
  1. (defun midverse (str / lst)
  2.   (defun al-string-to-ascii-list (str / alst cntr)
  3.     (if (= cntr '()) (setq cntr 1))
  4.     (while (<= cntr (strlen str))
  5.            (setq alst (cons (ascii (substr str cntr 1)) alst)
  6.                  cntr (1+ cntr)))
  7.     (reverse alst) )
  8.   (setq lst (al-string-to-ascii-list str))
  9.   (apply
  10.     'strcat
  11.     (mapcar
  12.       'chr
  13.       (append
  14.         (cons (car lst)
  15.                 (cdr (reverse (cdr lst))))
  16.         (list (last lst)))
  17.       )
  18.     )
  19.   )
Marc'Antonio Alessi
  • Marco
« Reply #6 on: March 07, 2022, 12:13:53 PM »
(defun Midverse_A (s / c L i e o)
  (setq L (strlen s) i (substr s 1 1) e (substr s L)  s (substr s 2 (- L 2)) o "" c 1)
  (repeat (strlen s)
    (setq o (strcat (substr s c 1) o)  c  (1+ c))
  (strcat i o e)
Better:
(defun Midverse_A2 (s / c L i e)
  (if (= 1 (setq L (strlen s)))
    s
      (setq i (substr s 1 1) e (substr s L)  s (substr s 2 (- L 2)) c 1)
      (repeat (strlen s)
        (setq e (strcat (substr s c 1) e)  c (1+ c))
      (strcat i e)
kirby
« Reply #7 on: March 07, 2022, 01:07:32 PM »
Building block approach...
  1. ; [challenge] A31 : Midverse
  2. ; Reverse the middle letters of a word.
  3. ; Write a procedure `midverse` that reverses all but the first and last letters of a word.
  4. ; For example:
  5. ;       (midverse "retinues")
  6. ;               should return "reunites".
  7. ;       Check that
  8. ;               (midverse (midverse [word]))
  9. ;                       leaves the word unchanged.
  10.
  11.
  12. (defun MidVerse-kirby (MyString / OutVal)
  13. ; [challenge] A31 : Midverse -  Reverse the middle letters of a word.
  14. ; Input:
  15. ;       MyString - (string) string to be modified
  16. ; Returns:
  17. ;       modfied string
  18. ; Uses custom functions:
  19. ;       StringReverse
  20. ;       StringSubst
  21.
  22. (setq OutVal nil)
  23.
  24. (if (eq (type MyString) 'STR)
  25.   (progn
  26.         (setq OutVal (stringreverse MyString))                                  ; Reverse
  27.         (setq OutVal (StringSubst OutVal (substr MyString 1 1) 1))              ; Replace first char
  28.         (setq OutVal (StringSubst OutVal (substr MyString (strlen MyString) 1) (strlen MyString)))      ; Replace last char
  29.   )
  30. )
  31.
  32. OutVal
  33. )
  34.
  35.
  36. (defun StringReverse (MyString / OutVal CNT CNT1)
  37. ; Reverse a string
  38. ; Input:
  39. ;       MyString - (string) string to be reverses
  40. ; Returns:
  41. ;       reversed string, or nil if input was not a string
  42.
  43. (setq OutVal nil)       ; null output
  44.
  45. (if (eq (type MyString) 'STR)
  46.   (progn
  47.         (setq OutVal "")
  48.
  49.         (setq CNT 0)
  50.         (repeat (strlen MyString)
  51.                 (setq CNT1 (- (strlen MyString) CNT))
  52.                 (setq OutVal (strcat OutVal (substr MyString CNT1 1)))
  53.                 (setq CNT (1+ CNT))
  54.         ) ; close repeat
  55.   )
  56. )
  57.
  58. OutVal
  59. )
  60.
  61.
  62.
  63. (defun StringSubst (MyString NewString Pos / OutVal L Part1 Part2)
  64. ; Substitude a new string in a string
  65. ; Input:
  66. ;       MyString - (string) a string
  67. ;       NewString - (string) substring to be inserted into MyString
  68. ;       Pos - (integer) position for substitution (1 to strlen).
  69. ; Returns:
  70. ;       modified string
  71.
  72. (setq OutVal nil)
  73.
  74. (setq L (strlen MyString))
  75.
  76. (if (and (>= Pos 1) (<= Pos L))
  77.   (progn
  78.         (setq Part1 (substr MyString 1 (1- Pos)))                       ; first part of string before Pos
  79.         (setq Part2 (substr MyString (1+ Pos) (- L Pos)))               ; last part of string after Pos
  80.
  81.         (setq OutVal (strcat Part1 NewString Part2))
  82.   )
  83. )
  84.
  85. OutVal
  86. )
  87.
  88.
« Reply #8 on: March 07, 2022, 01:45:29 PM »
Quick lunch break. Did this one in C for fun. It is also possible to do this with XOR as well (in C). I'll see if I can find some time to build that one too, later.
Code - C: [Select]
  1. #include <stdio.h>
  2. #include <string.h>
  3.
  4. char *strrev(char *s) {
  5.      /* Reverses the order of all characters in a string except the
  6.       * first and last--as well as the terminating byte */
  7.      char *start;
  8.      char *end;
  9.      char tmp;
  10.
  11.      /* Set pointer 'end' to last character in string */
  12.      end = s + strlen(s) - 1;
  13.      /* Eat last char */
  14.      --end;
  15.
  16.      /* Preserve pointer to start of string */
  17.      start = s;
  18.      /* Eat first char */
  19.      ++s;
  20.
  21.      /* Swap characters */
  22.      while(end >= s) {
  23.           tmp = *end;
  24.           *end = *s;
  25.           *s = tmp;
  26.           --end;
  27.           ++s;
  28.      }
  29.      return(start);
  30. }
  31.
  32. int main() {
  33.      char text[100];
  34.      char *p;
  35.
  36.      strcpy(text, "retinues");
  37.      p = strrev(text);
  38.      printf("\n%s",p);
  39.
  40.      return 0;
  41. }
  42.
« Reply #9 on: March 07, 2022, 07:42:09 PM »
Quick benchmark .. looks like VL wins for speed on this one.
Elapsed milliseconds / relative speed for 65536 iteration(s):
    (MIDVERSE-RJP "retinues").......2594 / 3.10 <fastest>
    (MIDVERSE-GILE "retinues")......3594 / 2.24
    (MIDVERSE_A "retinues").........4016 / 2.00
    (MIDVERSE_A2 "retinues")........4656 / 1.73
    (MIDVERSE-RJP2 "retinues")......5266 / 1.53
    (MIDVERSE-GILE2 "retinues").....5500 / 1.46
    (MIDVERSE-7 "retinues").........7422 / 1.08
    (MIDVERSE-KIRBY "retinues").....8047 / 1.00 <slowest>
---- Benchmark Utility: In memory of Michael Puckett ----
  1. (defun midverse-7 (str / lst)
  3.     (if (= cntr '())
  4.       (setq cntr 1)
  5.     )
  6.     (while (<= cntr (strlen str))
  7.       (setq alst (cons (ascii (substr str cntr 1)) alst)
  8.             cntr (1+ cntr)
  9.       )
  10.     )
  11.     (reverse alst)
  12.   )
  13.   (setq lst (al-string-to-ascii-list str))
  14.          (mapcar 'chr (append (cons (car lst) (cdr (reverse (cdr lst)))) (list (last lst))))
  15.   )
  16. )
  17. (defun midverse-rjp (str / a b c)
  18.   (setq a (vl-string->list str))
  19.   (setq b (car a))
  20.   (setq c (last a))
  21.   (setq a (cdr a))
  22.   (vl-list->string (append (list b) (cdr (reverse a)) (list c)))
  23. )
  24. (defun midverse-rjp2 (str / n r)
  25.   (setq n 1)
  26.   (repeat (- (strlen str) 2) (setq r (cons (substr str (setq n (1+ n)) 1) r)))
  27.   (strcat (substr str 1 1) (apply 'strcat r) (substr str (strlen str) 1))
  28. )
  29. (defun midverse-gile (s)
  30.   (vl-list->string
  31.     ((lambda (l)
  32.        (append (cons (car l) (cdr (reverse (cdr l)))) (list (last l)))
  33.      )
  34.       (vl-string->list s)
  35.     )
  36.   )
  37. )
  38. (defun midverse-gile2 (s / str->list)
  39.   (defun str->list (s)
  40.     (if (< 0 (strlen s))
  41.       (cons (ascii (substr s 1 1)) (str->list (substr s 2)))
  42.     )
  43.   )
  44.   (apply
  45.     'strcat
  46.     (mapcar
  47.       'chr
  48.       ((lambda (l) (append (cons (car l) (cdr (reverse (cdr l)))) (list (last l)))) (str->list s))
  49.     )
  50.   )
  51. )
  52. (defun midverse_a (s / c l i e o)
  53.   (setq l (strlen s)
  54.         i (substr s 1 1)
  55.         e (substr s l)
  56.         s (substr s 2 (- l 2))
  57.         o ""
  58.         c 1
  59.   )
  60.   (repeat (strlen s)
  61.     (setq o (strcat (substr s c 1) o)
  62.           c (1+ c)
  63.     )
  64.   )
  65.   (strcat i o e)
  66. )
  67. (defun midverse_a2 (s / c l i e)
  68.   (if (= 1 (setq l (strlen s)))
  69.     s
  70.     (progn (setq i (substr s 1 1)
  71.                  e (substr s l)
  72.                  s (substr s 2 (- l 2))
  73.                  c 1
  74.            )
  75.            (repeat (strlen s)
  76.              (setq e (strcat (substr s c 1) e)
  77.                    c (1+ c)
  78.              )
  79.            )
  80.            (strcat i e)
  81.     )
  82.   )
  83. )
  84. (defun midverse-kirby (mystring / outval)
  85.   (setq outval nil)
  86.   (if (eq (type mystring) 'str)
  87.     (progn (setq outval (stringreverse mystring)) ; Reverse
  88.            (setq outval (stringsubst outval (substr mystring 1 1) 1)) ; Replace first char
  89.            (setq outval (stringsubst outval (substr mystring (strlen mystring) 1) (strlen mystring)))
  90.                                         ; Replace last char
  91.     )
  92.   )
  93.   outval
  94. )
  95. (defun stringreverse (mystring / outval cnt cnt1) ; Reverse a string
  96.   (setq outval nil)                     ; null output
  97.   (if (eq (type mystring) 'str)
  98.     (progn (setq outval "")
  99.            (setq cnt 0)
  100.            (repeat (strlen mystring)
  101.              (setq cnt1 (- (strlen mystring) cnt))
  102.              (setq outval (strcat outval (substr mystring cnt1 1)))
  103.              (setq cnt (1+ cnt))
  104.            )                            ; close repeat
  105.     )
  106.   )
  107.   outval
  108. )
  109. (defun stringsubst (mystring newstring pos / outval l part1 part2)
  110.   (setq outval nil)
  111.   (setq l (strlen mystring))
  112.   (if (and (>= pos 1) (<= pos l))
  113.     (progn (setq part1 (substr mystring 1 (1- pos))) ; first part of string before Pos
  114.            (setq part2 (substr mystring (1+ pos) (- l pos))) ; last part of string after Pos
  115.            (setq outval (strcat part1 newstring part2))
  116.     )
  117.   )
  118.   outval
  119. )
  120. (benchmark '((midverse-rjp "retinues")
  121.              (midverse-rjp2 "retinues")
  122.              (midverse-gile "retinues")
  123.              (midverse-gile2 "retinues")
  124.              (midverse_a "retinues")
  125.              (midverse_a2 "retinues")
  126.              (midverse-kirby "retinues")
  127.              (midverse-7 "retinues")
  128.             )
  129. )
« Last Edit: March 07, 2022, 11:42:58 PM by ronjonp »
« Reply #10 on: March 07, 2022, 08:18:58 PM »
A procedural language that uses a C++ function to rip apart a string and another to stitch it back together again vs a procedural language's string access function(s); no contest! However, I'm actually surprised at how little it won by (it still surprises me how quick SUBSTR actually is!). And didn't Gile's first one use VL? How did that fare in the test?
I think I have a dumb idea to test out in the morning to possibly close the gap on the VL function just a bit.
« Reply #11 on: March 07, 2022, 11:44:39 PM »
Updated the benchmarks, I had Gile's code duplicated for both functions. My vl vs non vl function is 2x the speed.
gile
  • Marseille, France
« Reply #12 on: March 08, 2022, 01:36:28 AM »
An F# example using pattern matching.
Code - F#: [Select]
  1. let midverse s =
  2.     match Seq.toList s with
  3.     | x :: xs ->
  4.         match List.rev xs with
  5.         | y :: ys -> x :: ys @ [y] |> List.toArray |> System.String
  6.         | _ -> string x
  7.     | _ -> ""
« Reply #13 on: March 08, 2022, 08:16:40 AM »
Oh that's a neat trick. :)
« Reply #14 on: March 08, 2022, 08:51:48 AM »
  (repeat (strlen s)
  (strcat i o e)
It looks like my idea was already taken. I like it, Marc'Antonio.
Marc'Antonio Alessi
  • Marco
« Reply #15 on: March 08, 2022, 08:52:46 AM »
Another Vanilla:
(defun Midverse_A4 (s / L c e)
    ( (zerop (setq L (strlen s))) "" )
    ( (= 1 L)                      s )
    ( (setq c 1   e "")
      (repeat (- L 2)
        (setq e (strcat (substr s (setq c (1+ c)) 1) e))
      (strcat (substr s 1 1) e  (substr s L 1))
(setq aString "A")
(midverse_a4 aString) => "A"
(midverse-kirby aString) => "A"
(midverse-rjp aString) => "AA"
(midverse-gile aString) => "AA"
(midverse-rjp2 aString) => "AA"
(midverse-gile2 aString) => "AA"
(midverse-7 aString) => "AA"
(midverse_a4 "") => ""
(midverse-rjp "") => error
(midverse-gile "") => error
(midverse-rjp2 "") => error
(midverse-kirby "") => error
(midverse-gile2 "") => error
(midverse-7 "") => error
Marc'Antonio Alessi
  • Marco
« Reply #16 on: March 08, 2022, 08:53:49 AM »
Grazie  :-)
Marc'Antonio Alessi
  • Marco
« Reply #17 on: March 08, 2022, 09:16:38 AM »
Vl version:
(defun Midverse_A5 (s / L) ; similar
    ( (not (setq L (vl-string->list s))) "" )
    ( (cdr L)
      (vl-list->string (append (list (car L)) (cdr (reverse (cdr L))) (list (last L))))
    ( s )
kirby
« Reply #18 on: March 08, 2022, 09:23:20 AM »
Wanted to check out the speed loss in my version due to 2 external function calls.
(and notwithstanding coding time reduction by using library functions)
Also took the opportunity to correct null string problem noted by Marc'Antonio
  1. (defun MidVerseV2-kirby (MyString / OutVal L FirstChar LastChar CNT)
  2. ; [challenge] A31 : Midverse -  Reverse the middle letters of a word.  Version 2
  3. ; Input:
  4. ;       MyString - (string) string to be modified
  5. ; Returns:
  6. ;       modfied string
  7. ; Uses custom functions:
  8. ;       none!
  9.
  10. (setq OutVal "")
  11.
  12. (if (eq (type MyString) 'STR)
  13.   (progn
  14.
  15.         (setq L (strlen MyString))
  16.         (if (> L 0)
  17.           (progn
  18.                 (setq FirstChar (substr MyString 1 1))
  19.                 (setq LastChar (substr MyString L 1))
  20.
  21.                 (setq CNT L)
  22.                 (repeat (- L 2)
  23.                         (setq CNT (1- CNT))     ; work backwards
  24.                         (setq OutVal (strcat OutVal (substr MyString CNT 1)))
  25.                 ) ; close repeat
  26.
  27.                 (setq OutVal (strcat FirstChar OutVal LastChar))
  28.           )
  29.         ) ; close if
  30.   )
  31. ) ; close if
  32.
  33. OutVal
  34. )
  35.
Re-running RJP's benchmark analysis:
Elapsed milliseconds / relative speed for 8192 iteration(s):
    (MIDVERSE-RJP "retinues").........1531 / 3.45 <fastest>
    (MIDVERSE-GILE "retinues")........1610 / 3.28
    (MIDVERSE_A2 "retinues")..........1875 / 2.82
    (MIDVERSE-KIRBYV2 "retinues").....1922 / 2.75
    (MIDVERSE_A4 "retinues")..........1953 / 2.70
    (MIDVERSE_A "retinues")...........2157 / 2.45
    (MIDVERSE-KIRBY "retinues").......2266 / 2.33
    (MIDVERSE-RJP2 "retinues")........3110 / 1.70
    (MIDVERSE-7 "retinues")...........4922 / 1.07
    (MIDVERSE-GILE2 "retinues").......5281 / 1.00 <slowest>
So in my case about a 15% speed increase from eliminating the function calls, but results vary a bit each time you run the Benchmark.
And noting that I many not be using the latest version of MP's benchmark function, found here:
http://www.theswamp.org/index.php?topic=3952.0
« Reply #19 on: March 08, 2022, 09:34:01 AM »
@Kirby I use the same one (version). I don't know if anyone has another. I, myself, could never really modify MP's code all that much (I always found it difficult reading a program 10 lines at a time--because that's all that will fit on my screen at one time--). :p
Marc'Antonio Alessi
  • Marco
« Reply #20 on: March 08, 2022, 10:30:26 AM »
@Kirby my tests
>>>>>  (MIDVERSEV2-KIRBY "a") = "aa"
(setq aString "retinues")
--- Benchmark utility: In memory of Michael Puckett ---
    (MIDVERSE-GILE ASTRING)........1141 / 1.37 <fastest>
    (MIDVERSE-RJP ASTRING).........1172 / 1.33
    (MIDVERSE_A5 ASTRING)..........1187 / 1.32
    (MIDVERSE_A4 ASTRING)..........1515 / 1.03
    (MIDVERSEV2-KIRBY ASTRING).....1562 / 1 <slowest>
    (MIDVERSE-RJP ASTRING).........1125 / 1.32 <fastest>
    (MIDVERSE_A5 ASTRING)..........1141 / 1.3
    (MIDVERSE_A4 ASTRING)..........1484 / 1
    (MIDVERSEV2-KIRBY ASTRING).....1484 / 1 <slowest>
kirby
« Reply #21 on: March 08, 2022, 10:44:40 AM »
@JohnK - thanks. I guess that some folks have added headers attributing and honouring MP to their versions.  Reviewed the code, and yikes.  My aged and wee brain finds it hard to read and understand MP's code without adding lots of notes.
@Marc'Antonio - thanks. Looks like the versions that convert Strings to Lists and use vl- functions are the quickest.  And obviously the shortest code helps.
Marc'Antonio Alessi
  • Marco
« Reply #22 on: March 08, 2022, 12:25:44 PM »
... I guess that some folks have added headers attributing and honouring MP to their versions.  ...
Yes it is.
kirby
« Reply #23 on: March 08, 2022, 05:29:23 PM »
Awww
  3. ; Input:
  5. ; Returns:
  6. ;       modfied string
  8. ;       none!
  9.
  11.
  13.   (progn
  14.
  16.         (if (> L 2)
  17.           (progn
  20.
  21.                 (setq CNT L)
  22.                 (repeat (- L 2)
  26.
  28.           )
  29.           (progn
  30.                 ; catch short string
  31.                 (setq OutVal MyString)
  32.           )
  33.         ) ; close if
  34.   )
  35. ) ; close if
  36.
  37. OutVal
  38. )
  39.
pBe
« Reply #24 on: March 09, 2022, 11:57:39 AM »
Most likely already taken
  1. (defun midverse (str / n s)
  2.   (setq n 1 s "" )
  3.   (strcat (substr str 1 1)
  4.           (repeat (- (strlen str) 2)
  5.             (setq s (strcat (substr str (setq n (1+ n)) 1) s))
  6.             s
  7.           )
  8.           (substr str (1+ n))
  9.   )
  10. )
"", "A" ,"AA"
  1. (defun midverse (str / sl n s)
  2.   (cond
  3.     ((<= (setq sl (strlen str)) 2) str)
  4.     ((setq n 1
  5.            s ""
  6.      )
  8.              (repeat (- sl 2)
  9.                (setq s (strcat (substr str (setq n (1+ n)) 1) s))
  10.                s
  11.              )
  12.              (substr str (1+ n))
  13.      )
  14.     )
  15.   )
  16. )
« Last Edit: March 09, 2022, 12:11:08 PM by pBe »
