Author Topic: [challenge] A30 : Sum of Missing Numbers  (Read 1719 times)
« on: March 02, 2022, 09:58:49 AM »
Create a function that returns the sum of missing numbers in a list.
Examples
(sumMissing '(1 3 5 7 10))
> 29
;; 2 + 4 + 6 + 8 + 9
(sumMissing '(10 7 5 3 1))
> 29
(sumMissing '(10 20 30 40 50 60))
> 1575
pBe
Re: [challenge] A30 : Sum of Missing Numbers
« Reply #1 on: March 02, 2022, 11:34:28 AM »
  1. (defun sumMissing ( l / lv ms)
  2.   (repeat (- (setq lv (apply 'max l))
  3.              (apply 'min l)
  4.           )
  5.     (if (not (member (setq lv (1- lv)) l))
  6.       (setq ms (cons lv ms))
  7.     )
  8.   )
  9.   (apply '+ ms)
  10. )
  2. (setq ms 0)
  3.   (repeat (- (setq lv (apply 'max l))
  4.              (apply 'min l)
  5.           )
  6.     (if (not (member (setq lv (1- lv)) l))
  7.       (setq ms (+ ms lv))
  8.     )
  9.   )
  10. ms
  11. )
« Last Edit: March 02, 2022, 11:41:03 AM by pBe »
« Reply #2 on: March 02, 2022, 11:59:05 AM »
pretty straight forward approach so mine was similar.
  1. (defun summissing (lst)
  2.   ;; summissing
  3.   ;; this function will sum the missing values in list
  4.   ;; of integers.
  5.   ;;
  6.   ;; (sumMissing '(1 3 5 7 10))
  7.   ;; > 29
  8.   (setq cntr (apply 'max lst)
  9.         min? (apply 'min lst)
  10.         sum 0)
  11.   (while (>= cntr min?)
  12.          (if (not (member cntr lst))
  13.            (setq sum (+ sum cntr)))
  14.          (setq cntr (1- cntr))
  15.          )
  16.   sum
  17.   )
gile
  • Marseille, France
« Reply #3 on: March 02, 2022, 12:08:27 PM »
  1. (defun sumMissing (l / i n)
  2.   (setq n 0)
  3.   (repeat (setq i (1+ (apply 'max l)))
  4.     (setq n (+ n (setq i (1- i))))
  5.   )
  6.   (- n (apply '+ l))
  7. ))
_$ (sumMissing '(1 3 5 7 10))
29
_$ (sumMissing '(10 7 5 3 1))
29
_$ (sumMissing '(5 1 10 3 7))
29
_$ (sumMissing '(10 20 30 40 50 60))
1620
« Last Edit: March 02, 2022, 12:28:54 PM by gile »
pBe
« Reply #4 on: March 02, 2022, 12:31:16 PM »
1620
What's going on there?
(sumMissing:gile '(45 47 98 104)) --> 5166
(sumMissing '(45 47 98 104)) -->  4176
And this is flawed
  1. (Defun sumMissing:math (l)
  2.   (setq lo (apply 'min l) hi (apply 'max l)
  3.   )
  4.   (- (* (/ (+ (- hi lo)) 2) (+ lo hi))
  5.      (- (apply '+ l) (+ lo hi))
  6.   )
  7. )
(sumMissing:math '(45 47 98 104))
4176
_$ (sumMissing:math '(1 3 5 7 10))
29
_$ (sumMissing:math '(10 20 30 40 50 60))
1610
« Last Edit: March 02, 2022, 12:40:51 PM by pBe »
gile
  • Marseille, France
« Reply #5 on: March 02, 2022, 12:44:47 PM »
My upper routine is wrong.
This one works as expected:
  2.   (setq n (apply 'max l))
  3.   (repeat (- (setq i n) (apply 'min l))
  5.   )
  7. )
Marc'Antonio Alessi
  • Marco
« Reply #6 on: March 02, 2022, 01:14:09 PM »
too late…
(defun SumMissing_A (L / m n o)
  (setq m (apply 'max L)  n (apply 'min L) o 0)
  (repeat (- m n) (setq o (+ o n) n (1+ n)))
  (- (+ o m) (apply '+ L))
kirby
« Reply #7 on: March 02, 2022, 01:33:29 PM »
Yet another...
  1. (defun C:Test-A30 ( / MyTestLists CNT MyList Ans)
  2. ; Test routine for Challenge A30
  3.
  4. (setq MyTestLists (list
  5.         '(1 3 5 7 10)           ; 29
  6.         '(10 7 5 3 1)           ; 29
  7.         '(10 20 30 40 50 60)    ; 1575
  8. ))
  9.
  10. (setq CNT 0)
  11. (repeat (length MyTestLists)
  12.         (setq MyList (nth CNT MyTestLists))
  13.         (prompt "\n  List = ")(princ MyList)
  14.
  15.         (setq Ans (SumMissing-kirby MyList))
  16.         (prompt "\n    --> ")(princ Ans)
  17.         (princ)
  18.
  19.         (setq CNT (1+ CNT))
  20. )
  21. )
  22.
  23. (defun SumMissing-kirby (MyList /
  24.                         Verbose OutVal CNT Item1 Item2 Diff StartVal CNT1 NextValue
  25.                         )
  26. ; Sum missing values in a list of integers
  27. ; Input:
  28. ;       MyList - (list) list of integers, sorted in either ascending or descending order
  29. ; Returns:
  30. ;       sum of missing values (integer)
  31.
  32. (setq Verbose 0)        ; 1 to show additional/debug info
  33.
  34. (setq OutVal 0)
  35.
  36. ; Loop though list
  37. (setq CNT 0)
  38. (repeat (1- (length MyList))
  39.         (setq Item1 (nth CNT MyList))
  40.         (setq Item2 (nth (1+ CNT) MyList))
  41.         (setq Diff (abs (- Item2 Item1)))       ; difference between values
  42.         (setq StartValue (min Item1 Item2))     ; start with minimum so increment is 1+
  43.
  44.         (if (eq Verbose 1)
  45.           (progn
  46.                 (prompt "\n  Values ")(princ Item1)(prompt "  ")(princ Item2)(prompt "  Difference = ")(princ Diff)(princ)
  47.           )
  48.         )
  49.
  50.         ; loop through gap between values
  51.         (if (> Diff 1)
  52.           (progn
  53.                 (setq NextValue StartValue)     ; initialize next value to sum
  54.
  55.                 (repeat (1- Diff)
  56.                         (setq NextValue (1+ NextValue))         ; update next value
  57.                         (setq OutVal (+ OutVal NextValue))      ; sum
  58.
  59.                         (if (eq Verbose 1)
  60.                           (progn
  61.                                 (prompt "\n    Next Value = ")(princ NextValue)(prompt "  Running Total = ")(princ OutVal)(princ)
  62.                           )
  63.                         )
  64.                 ) ; close repeat
  65.           )
  66.         ) ; close if
  67.
  68.         (setq CNT (1+ CNT))
  69. ) ; close repeat
  70. OutVal
  71. )
  72.
Results:
Command: TEST-A30
  List = (1 3 5 7 10)
    --> 29
  List = (10 7 5 3 1)
    --> 29
  List = (10 20 30 40 50 60)
    --> 1575
bruno_vdh
« Reply #8 on: March 02, 2022, 04:48:56 PM »
Hello, by taking up an answer made previously on a French-speaking forum
https://www.developpez.net/forums/d1446541/autres-langages/langages-fonctionnels/lisp/lisp-somme-n-premiers-nombres/#post7863527
Sum of the first N natural integers
  1. ;; Somme des N premiers entiers naturels / Sum of the first N natural integers
  2. (defun Snp (n) (/ (* n (1+ n)) 2))
For the record, it is with this reasoning by recurrence S = 1 + 2 + 3 + ... + (n-1) + n
that the little Carl Friedrich Gauss (nine years old at the time) deduced the following formula S= n(n+1)/2,
concerning the sum of the first N natural integers.
sumMissing(l) = (Snp (max(l)) - (Snp (min(l) - 1)) - (Somme(l))
  1. (defun sumMissing (l) (- (Snp (apply 'max l)) (Snp (1- (apply 'min l))) (apply '+ l)))
1575
_$(sumMissing '(1 3 5 7 10))
29
« Last Edit: March 02, 2022, 05:38:35 PM by bruno_vdh »
« Reply #9 on: March 02, 2022, 09:44:23 PM »
Great post!
Marc'Antonio Alessi
  • Marco
« Reply #10 on: March 03, 2022, 03:37:26 AM »
(defun SumMissing_A2 (L / m n)
  (setq m (apply 'max L)  n (apply 'min L))
  (- (/ (* (+ n m) (- m n -1)) 2)  (apply '+ L))
kirby
« Reply #11 on: March 03, 2022, 10:18:02 AM »
@bruno_vdh
Thanks!  Interesting and efficient solution.
apricot125
  • Mosquito
« Reply #12 on: July 11, 2022, 11:05:06 PM »
_$ (sumMissing_A2 '(1 3 5 7  7 10))
22
it's may not correct.
Marc'Antonio Alessi
  • Marco
« Reply #13 on: July 12, 2022, 04:23:38 PM »
22
(defun sumMissing (l / i n) ; gile
  (- n (apply '+ l))
(sumMissing    '(1 3 5 7 7 10)) => 22
(sumMissing_A  '(1 3 5 7 7 10)) => 22
(sumMissing_A2 '(1 3 5 7 7 10)) => 22
