Author Topic: [challenge] A27 : delete-if / delete-if-not  (Read 2958 times)
« on: February 23, 2022, 08:00:39 AM »
Derive a function that accepts a function and deletes a member from a list if a member is...
(delete-if oddp '(1 2 3 4 5 6 7 8))
> (2 4 6 8)
AND/OR
(delete-if evenp '(1 2 3 4 5 6 7 8))
> (1 3 5 7)
Derive a function that accepts a function and deletes a member from a list if a member is NOT...
(delete-if-not oddp '(1 2 3 4 5 6 7 8))
> (1 3 5 7)
AND/OR
(delete-if-not evenp '(1 2 3 4 5 6 7 8))
Re: [challenge] A27 : delete-if / delete-if-not
« Reply #1 on: February 23, 2022, 08:03:22 AM »
Quick one -
  1. (defun deleteif ( f l )
  2.     (cond
  3.         (   (not l) l)
  4.         (   (apply f (list (car l))) (deleteif f (cdr l)))
  5.         (   (cons (car l) (deleteif f (cdr l))))
  6.     )
  7. )
  1. _$ (deleteif '(lambda ( x ) (zerop (rem x 2))) '(0 1 2 3 4 5 6 7 8))
  2. (1 3 5 7)
« Reply #2 on: February 23, 2022, 08:04:42 AM »
Or, an iterative solution:
  2.     (apply 'append (mapcar '(lambda ( x ) (if (not (apply f (list x))) (list x))) l))
  3. )
Or:
  2.     (apply 'append
  3.         (mapcar '(lambda ( a b ) (if (not a) b))
  4.             (mapcar f l)
  5.             (mapcar 'list l)
  6.         )
  7.     )
  8. )
Or imperatively rather than functionally:
  1. (defun deleteif ( f l / r )
  2.     (foreach x l (or (apply f (list x)) (setq r (cons x r))))
  3.     (reverse r)
  4. )
« Last Edit: February 23, 2022, 08:11:15 AM by Lee Mac »
gile
  • Marseille, France
« Reply #3 on: February 23, 2022, 08:26:45 AM »
To avoid calling apply (or eval) at each loop, it would be more efficient to set f to (eval f) before the loops and simply call (f item) at each loop.
  1. (defun deleteif (f l / loop)
  2.   (defun loop (f l)
  3.     (cond
  4.       ((not l) l)
  5.       ((f (car l)) (deleteif f (cdr l)))
  6.       ((cons (car l) (deleteif f (cdr l))))
  7.     )
  8.   )
  9.   (loop (eval f) l)
  10. )
« Last Edit: February 23, 2022, 08:49:30 AM by gile »
« Reply #4 on: February 23, 2022, 08:33:20 AM »
Mine:
  1. (defun oddp (int)
  2.   (eq 1 (logand int 1)))
  3.
  4. (defun evenp (int)
  5.   (eq 0 (logand int 1)))
  6.
  7. (defun delete-if (proc lst)
  8.   (apply
  9.     'append
  10.     (mapcar
  11.       '(lambda (x)
  12.          (if (not (eval (list proc x))) (list x)))
  13.       lst)) )
  14.
  15. (defun delete-if-not (proc lst)
  16.   (apply
  17.     'append
  18.     (mapcar
  19.       '(lambda (x)
  20.          (if (eval (list proc x)) (list x)))
  21.       lst)) )
  22.
  23. ; (delete-if 'oddp '(1 2 3 4 5 6 7 8))
  24. ; (delete-if 'evenp '(1 2 3 4 5 6 7 8))
  25. ; (delete-if-not 'oddp '(1 2 3 4 5 6 7 8))
  26. ; (delete-if-not 'evenp '(1 2 3 4 5 6 7 8))
  27.
Command: (delete-if 'oddp '(1 2 3 4 5 6 7 8))
(2 4 6 8)
Command: (delete-if 'evenp '(1 2 3 4 5 6 7 8))
(1 3 5 7)
Command: (delete-if-not 'oddp '(1 2 3 4 5 6 7 8))
(1 3 5 7)
Command: (delete-if-not 'evenp '(1 2 3 4 5 6 7 8))
(2 4 6 8)
Command: (setq lst '(0 1 2 3 4 5 6 7 8 9))
Command: (mapcar '(lambda (f) (delete-if f lst)) '(oddp evenp))
((0 2 4 6 8) (1 3 5 7 9))
(defun oddp (int)
(defun evenp (int)
  (apply
    'append
    (mapcar
      '(lambda (x)
         (if (not (proc x)) (list x)))
      lst)) )
  (apply
    'append
    (mapcar
      '(lambda (x)
         (if (proc x) (list x)))
      lst)) )
EDIT: Corrected code to allow for quoted function arguments.
« Last Edit: February 23, 2022, 09:01:20 AM by JohnK »
gile
  • Marseille, France
« Reply #5 on: February 23, 2022, 08:46:40 AM »
@JohnK
To be consistent with other AutoLISP higher order functions, the function passed as argument should be quoted.
  1. (setq lst '(0 1 2 3 4 5 6 7 8 9)
  2. (mapcar '(lambda (f) (delete-if f lst)) '(oddp evenp))
« Reply #6 on: February 23, 2022, 09:03:43 AM »
gile, you are a cruel man! :)
We are like children to you aren't we?
@JohnK
gile
  • Marseille, France
« Reply #7 on: February 23, 2022, 09:11:01 AM »
@JohnK
Not at all. Look at Lee's replies he handled this using apply. We just have already played with building higher order functions some times ago.
bruno_vdh
« Reply #8 on: February 23, 2022, 09:52:34 AM »
  3.     (cond
  4.       ((not l) l)
  7.     )
  8.   )
  10. )
Hello (gile),
Small write error, because it is on this condition alone..  :wink:
(not getting out of the loop)
  3.     (cond
  4.       ((not l) l)
  5.       ((f (car l)) (loop f (cdr l)))
  6.       ((cons (car l) (loop f (cdr l))))
  7.     )
  8.   )
  10. )
  11.
Small precision, because few people here know that in terms of lisp I owe you a lot, if that's not all...
« Last Edit: February 23, 2022, 10:18:06 AM by bruno_vdh »
kirby
« Reply #9 on: February 23, 2022, 10:16:47 AM »
one more...
  1. (defun C:Test-A27 ( / MyFuncList MyTestList MySwitchList CNT MyFunc MySwitch Ans)
  2.
  3. ; Test input
  4. (setq MyFuncList (list oddp evenp oddp evenp))
  5. (setq MyTestList (list 0 1 2 3 4 5 6 7 8))
  6. (setq MySwitchList (list 0 0 1 1))
  7.
  8. (prompt "\nTest List = ")(princ MyTestList)(princ)
  9.
  10. (setq CNT 0)
  11. (repeat (length MyFuncList)
  12.         (setq MyFunc (nth CNT MyFuncList))
  13.         (setq MySwitch (nth CNT MySwitchList))
  14.
  15.         (setq Ans (delete-if-kirby MyFunc MyTestList MySwitch))
  16.
  17.         (prompt "\n  Func = ")(princ MyFunc)
  18.         (prompt "  Invert? = ")(princ MySwitch)
  19.         (prompt "  Ans = ")(princ Ans)
  20.         (princ)
  21.
  22.         (setq CNT (1+ CNT))
  23. ) ; close repeat
  24.
  25. )
  26.
  27. (defun delete-if-kirby (MyFunc MyList MySwitch / OutList CNT MyItem)
  28. ; [challenge] A27 : delete-if / delete-if-not
  29. ; function that accepts a function and deletes a member from a list if a member is ...  / or if a member is NOT...
  30. ; Input:
  31. ;       MyFunc - (name of autolisp function) function must be appropriate for operations on list items (e.g. can't test if a string is an even number)
  32. ;       MyList - (list) a list or numbers or strings
  33. ;       MySwitch - (integer) code to control function behaviour
  34. ;                       0 = use function to test for item deletion
  35. ;                       1 = inverse function (NOT)
  36. ; Returns:
  37. ;       modified list
  38.
  39. (setq OutList nil)
  40.
  41. (if MyList
  42.   (progn
  43.         (setq CNT 0)
  44.         (repeat (length MyList)
  45.                 (setq MyItem (nth CNT MyList))
  46.
  47.                 (cond
  48.                         ((eq MySwitch 0)                ; delete if function is true
  49.                           (progn
  50.                                 (if (not (MyFunc MyItem))
  51.                                         (setq OutList (cons MyItem OutList))
  52.                                 )
  53.                           )
  54.                         )
  55.                         ((eq MySwitch 1)                ; Inverse case: delete if function is NOT true
  56.                           (progn
  57.                                 (if (MyFunc MyItem)
  58.                                         (setq OutList (cons MyItem OutList))
  59.                                 )
  60.                           )
  61.                         )
  62.                 ) ; close cond
  63.
  64.                 (setq CNT (1+ CNT))
  65.         ) ; close repeat
  66.
  67.         (setq OutList (reverse OutList))
  68.   )
  69. )
  70.
  71. OutList
  72. )
  73.
  74. ; Test predicate functions
  75. (defun Evenp (MyVal / )
  76. ; Return T is value is Even
  77.         (if (equal (rem MyVal 2.0) 0.0 1e-8)
  78.                 T
  79.         )
  80. )
  81.
  82. (defun Oddp (MyVal / )
  83. ; Return T if value is Odd
  84.         (if (equal (rem MyVal 2.0) 1.0 1e-8)
  85.                 T
  86.         )
  87. )
  88.
  89. (defun Positivep (MyVal / )
  90. ; Return T if value is positive
  91.         (if (not (minusp MyVal))
  92.                 T
  93.         )
  94. )
  95.
  96.
« Reply #10 on: February 23, 2022, 10:49:09 AM »
Many of us owe gile a lot for many programming languages.
gile
  • Marseille, France
« Reply #11 on: February 23, 2022, 11:07:52 AM »
Hello (gile),
  3.     (cond
  4.       ((not l) l)
  7.     )
  8.   )
  10. )
  11.
Oops!!!... I to quickly pasted Lee's code...
We all owe to each other due to the sharing here, at TheSwamp, and elsewhere.
pBe
« Reply #12 on: February 23, 2022, 01:36:14 PM »
Still not sure if i followed the rules. very difficult to not to look at the other's posts.
Let me know if this is acceptable or i'm totally off
  1. (defun delete-if:Pbe (pr l)
  2.   ((lambda (ls)
  3.      (foreach itm l
  4.        (if (eval (list pr itm))
  5.          (setq ls (cons itm ls))
  6.        )
  7.      )
  8.      (reverse ls)
  9.    )
  10.     nil
  11.   )
  12. )
I kept the same logic as my blundered post :)
All the good ones are taken.
  1. (defun _even (n / o)
  2.     (while (null
  3.              (cond
  4.                ((setq o (= n 1)))
  5.                ((zerop n))
  6.              )
  7.            )
  8.       (setq n (- n 2))
  9.     )
  10.     o
  11.   )
  12.
  13. (defun _odd  (n / e)
  14.     (while (null
  15.              (cond
  16.                ((setq e (zerop n)))
  17.                ((= n 1))
  18.              )
  19.            )
  20.       (setq n (- n 2))
  21.     )
  22.     e
  23.   )
« Last Edit: February 24, 2022, 02:15:33 AM by pBe »
« Reply #13 on: February 23, 2022, 02:15:08 PM »
@pBe
Nice but your function does not remove items from a list based on a condition (-i.e. a function). Your function will just remove the odd items from a list.
pBe
« Reply #14 on: February 23, 2022, 07:35:26 PM »
@pBe
:D Sorry about that, I honestly did not read through the entire discussion, i'll repost later today.
