Author Topic: VBA macro already loaded?  (Read 2533 times)
Amsterdammed
« on: June 24, 2005, 04:54:51 AM »
Hello everybody,
I load a VBA macro with the  .mnl file of an application.
But i want it only loaded once, with teh first dwg. How can i find out if a dvb is already loaded?
Thanks, Bernd
« Reply #1 on: June 24, 2005, 07:54:18 AM »
« Last Edit: October 21, 2005, 12:23:21 PM by CAB »
Amsterdammed
« Reply #2 on: June 24, 2005, 10:04:10 AM »
:D  Thanks CAB and Jeff :D
« Reply #3 on: June 24, 2005, 01:33:46 PM »
Amsterdammed: You're welcome :D
CAB: Don't you ever sleep? :shock: I see you posted to AUGI around midnite, your time, and then you are posting here first thing in the morning (long before I'm awake). And I thought I was attached to this keyboard.  :P
« Reply #4 on: June 24, 2005, 02:33:28 PM »
Amsterdammed's avatar says it all :)
They say when you get older you don't need the sleep.
That's BS
You need the sleep but your body won't let you sleep.
If I thought I would have lived this long I would have taken better care of myself.:)
« Reply #5 on: June 24, 2005, 03:40:02 PM »
Quote from: CAB
Wow, all I can say is "AMEN!" :keb:  :D
Amsterdammed
« Reply #6 on: June 25, 2005, 08:37:34 AM »
Don't get me wrong CAB, my avatar is  just showing  me falling asleep because I work so hard. :wink:
« Reply #7 on: June 25, 2005, 09:37:26 AM »
That's the way I understood it.
I often put in 10 to 12 hour days behind the keyboard.
But still have time to write a lisp or two, usually
after the 12 hour day. So I'm falling asleep at the keyboard too.
David Hall
  • Automatic Duh Generator
Re: VBA macro already loaded?
« Reply #8 on: October 21, 2005, 12:03:39 PM »
CAB, the link isn't working, any ideas?
Bob Wahr
« Reply #9 on: October 21, 2005, 12:07:01 PM »
try this Duh
David Hall
« Reply #10 on: October 21, 2005, 12:19:41 PM »
I thought vl-vbaload turned off Filedia?  did they fix this in 2006?
