I have a weird problem with some polygons in cad, Geometric Center is not accurate in the attached file.
Does someone tell me what the problem is?
In my source bellow work fine. I use LeeMac_Centroid have no bugError.
You always, you keep the "Osmode"=207, otherwise the programe.lsp
(rtFail "pp_civileng_leecentroid_autoexec_jcpin25.lsp")
You found the sourceEncrypted, here on nextLine
(Click Here,Click Here)If you need the source'NativeDef (not protected in ascii.lisp) (Not jc_pin25)
--> then you replay here.
