Author Topic: Perimeter (length) of the offset without doing the offset  (Read 1457 times)
Marc'Antonio Alessi
  • Marco
« on: August 14, 2021, 03:39:12 AM »
Is possible to calculate the length of the offset of a polyline without doing the offset?
The perimeter is internal if the polyline is closed and external if open. Currently I do the internal and external offset and take the one with a greater or lesser length depending on whether the polyline is open or closed, then I delete the offset.
VovKa
  • Ukraine
Re: Perimeter (length) of the offset without doing the offset
« Reply #1 on: August 14, 2021, 07:02:50 AM »
if the polyline is open one can not decide which offset is internal or external by just measuring the length
VovKa
  • Ukraine
« Reply #3 on: August 14, 2021, 09:24:24 AM »
It is true  :yes: :knuppel2: :)
so there is no solution
we can only calculate the length of the line offset to the left or to the right side
Marc'Antonio Alessi
  • Marco
« Reply #4 on: August 14, 2021, 09:47:20 AM »
i am trying to use an idea of RJP where the resulting areas are compared (i think for my polyline types this is enough):
(defun c:foo (/ _off a b c d o o1 o2 p s x)
  ;; RJP - 07.17.2018
  ;; Offsets a pline twice and joins them
  ;; Does not work with polylines that have arc segments
  (defun _off (o d / r)
    (cond ((= 'list (type (setq r (vl-catch-all-apply 'vlax-invoke (list o 'offset d))))) (car r)))
  (cond ((and (setq s (ssget ":L" '((0 . "lwpolyline") (-4 . ">") (90 . 2))))
              (not (initget "Outside Inside"))
              (setq p (cond ((getkword "\nOffset [Outside/Inside] <Outside>: "))
                            ("Outside")
         (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
           (setq c nil)
           (setq o (vlax-ename->vla-object e))
           (setq a (mapcar 'cdr (vl-remove-if '(lambda (x) (/= 10 (car x))) (entget e))))
           (setq
             o (vl-remove
                 'nil
                 (mapcar
                   '(lambda (x) (cond ((setq d (_off o (x 45))) (list d x (vlax-curve-getarea d)))))
                   (list + -)
           (cond ((= 2 (length o))
                  (setq o (vl-sort o '(lambda (r j) (< (caddr r) (caddr j)))))
                  (cond ((= p "Outside") (setq o (reverse o))))
                  (vla-delete (car (cadr o)))
                  (setq o1 (caar o))
                  (setq b (vlax-get o1 'coordinates))
                  (vlax-put o1 'coordinates (append (car a) b (last a)))
                  (setq o2 (car (vlax-invoke o1 'offset ((cadar o) 10))))
                  (setq a (vlax-get o1 'coordinates))
                  (setq b (vlax-get o2 'coordinates))
                  (while b (setq c (cons (list (car b) (cadr b)) c)) (setq b (cddr b)))
                  (vlax-put o1 'coordinates (append a (apply 'append c)))
                  (vla-put-closed o1 :vlax-true)
                  (vla-put-color o1 30)
                  (vla-delete o2)
VovKa
  • Ukraine
Marc'Antonio Alessi
  • Marco
« Reply #6 on: August 14, 2021, 11:11:36 AM »
Pseudo code:
(defun ALE_Draw_Offset (VlaObj OffDst / RetVal)
  (cond ( (= 'list (type (setq RetVal (vl-catch-all-apply 'vlax-invoke (list VlaObj 'offset OffDst))))) (car RetVal) ) )
(defun ALE_Pline_TwiceOffset (VlaObj OffDst)
  (vl-remove 'nil
    (mapcar
     '(lambda (LmbDat)
        (cond ( (setq CoDLst (FunOff VlaObj (LmbDat OffDst))) (list CoDLst LmbDat (vlax-curve-getarea CoDLst)) ))
      (list + -)
(defun ALE_Pline_OffsetInOut (InfLst Out_In) ; Out_In 0 = Out - 1 = In
  (if (zerop Out_In)
    (setq InfLst (reverse (vl-sort InfLst '(lambda (r j) (< (caddr r) (caddr j))))))
    (setq InfLst (vl-sort InfLst '(lambda (r j) (< (caddr r) (caddr j)))))
  (vla-delete (car (cadr InfLst)))
  (caar InfLst)
(setq InfLst (ALE_Pline_TwiceOffset vvv 30))
(vla-get-Length (ALE_Pline_OffsetInOut InfLst 0))
