Author Topic: found a function: get-logical-drives  (Read 1549 times)
baitang36
« on: August 08, 2021, 07:44:05 AM »
Using this function, you can get all drive letters.
However, this function is a reserved function of AutoCAD and is not written to public documents. It can only be invoked in Fas and can not be used in LSP.
An example is attached
It's Alive!
  • Retired
  • AKA Daniel
Re: found a function: get-logical-drives
« Reply #1 on: August 08, 2021, 08:29:33 AM »
should be able to do this via COM and WMI service
see https://docs.microsoft.com/en-us/windows/win32/wmisdk/wmi-tasks--disks-and-file-systems
edit "Scripting.FileSystemObject" Drives collection maybe
« Last Edit: August 08, 2021, 08:41:27 AM by It's Alive! »
mm_clover
  • Mosquito
« Reply #2 on: August 08, 2021, 09:21:42 AM »
谢谢分享Thank you for sharing!
Rod
« Reply #3 on: August 08, 2021, 06:16:18 PM »
Cool baitang36
If anyone is looking for an uncompiled alternative HighFlyingBird has created sometheing
http://www.theswamp.org/index.php?topic=38102.msg431146#msg431146
Cheers, Rod.
"All models are wrong, some models are useful" - George Box
BIGAL
  • 40 + years of using Autocad
« Reply #4 on: August 08, 2021, 09:45:30 PM »
You can find drives
; drive type 1 is a usb 2 hard disk
(defun UsbDriveSerialNumber ( / fso dr)
  (setq fso (vlax-create-object "Scripting.FileSystemObject"))
  (vlax-for d (vlax-get fso 'Drives)
  (= (Vlax-get  d 'DriveType) 2)
      (setq dr (cons (list (vla-get-path d) (vla-get-SerialNumber d)) dr)
  (vlax-release-object fso)
  (reverse dr)
(UsbDriveSerialNumber)
baitang36
« Reply #5 on: August 10, 2021, 03:19:29 AM »
You can find drives
  (reverse dr)
thank you
d2010
« Reply #6 on: August 10, 2021, 05:49:39 AM »
How to inject userCPU-ID-codes directly to programe_jc_aro10.Lsp.Txt??
Eu am nevoie de ajutor, sa compilam sursa LISP blochata pe seriaL CPU-id
Daca sursa este compilata pe serial CPU-ID, atunci chair Tu nu poti executa
programe.LSP.txt chiar in calculatorul baitang36Win10.
How to encrypt programe.Lsp.Txt with  only, once CPU-ID-code,before FAs or before.Vlx ??
  1. Please help me, I cannot make only-Alone?>
:whistling:
:whistling:
[quote author=baitang36 link=topic=56936.msg605882#msg605882 date=1628579969]
You can find drives
  (reverse dr)
[/quote]
Tu nu nevoie de extragerea de informatii Hard (CPU-serial, Usb-Serial)
deoarece tu downgrade programul.Vlx, si in acest mod, cerintele soft
programului VLX creste dificulatatile de functionare a programului.VLX
si apar multe incompatibilitatii software , atunci cand Tu compilezi LSP to VLX,
LSP to DES, LSP to ELC(NanoCad)...
« Last Edit: August 10, 2021, 06:12:20 AM by d2010 »
