Author Topic: is there a way for "if path nil, use this path"?  (Read 1088 times)
tedg
« on: August 04, 2021, 01:23:43 PM »
Hello all, been a while since I posted here..
Hoping this is an easy fix or there's maybe an easier way.
I /we have a custom "revcloud" routine that we use, that inserts a rev triangle block (delta with attributes) from the same location that the lisp routine lives on our server.
The issue is, with most of us working remotely, and we use Dropbox as our virtual server when away from the office, the path isn't the same as if in the office.
The office computers don't/won't have Dropbox loaded, as I've been told.
(example)
(command "-insert" "C:\\Dropbox\\CADD\\Symbols\\Revision") ;;dropbox location
;;vs
(command "-insert" "Y:\\Symbols\\Revision") ;;office server
So is there a way to force which drive in gets the dwg file from depending on where the routine lives?
Any other ideas?
I'm trying to make it idiot-proof for people using the routine no matter where they are working, and avoid having duplicates of the routine with different names (which may be my option B).
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
mhupp
Re: is there a way for "if path nil, use this path"?
« Reply #1 on: August 04, 2021, 01:36:40 PM »
(if (not (findfile (setq path "C:\\Dropbox\\CADD\\Symbols\\Revision")))
  (setq path "Y:\\Symbols\\Revision")
(vl-cmdf "-insert" path)
tedg
« Reply #2 on: August 04, 2021, 02:31:20 PM »
Thanks mhupp, this helped!
« Reply #3 on: August 05, 2021, 10:11:38 AM »
Can also be written like this:
  1. (setq path (cond ((findfile "C:\\Dropbox\\CADD\\Symbols\\Revision"))
  2.                  ((findfile "Y:\\Symbols\\Revision"))
  3.            )
  4. )
