Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Correct me if I'm wrong...but strcase sets case
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Correct me if I'm wrong...but strcase sets case (Read 1096 times)
jlogan02
Bull Frog
on:
July 28, 2021, 04:51:00 PM »
Code - Auto/Visual Lisp:
[Select]
setq
tagname1
"DESIGNER"
setq
ss1
ssget
"x"
2
"TBLK_ATT_CTL"
66
1
repeat
setq
x
sslength
ss1
setq
obj1
vlax
ename
vla-object
ssname
ss1
setq
x
x
1
if
vla-get-hasattributes
obj
:vlax-true
foreach
att1
vlax-invoke
obj1 'getattributes
if
tagname1
strcase
vla-get-tagstring
att1
vla-put-textstring
att1
substr
getvar
"loginname"
1
3
In this code I'm setting the case of tagname1 to lower case. Correct?
I've tested 4 different users and tagname1 gets filled in with lowercase in all cases but mine. I checked their actual LogInName with
[Select]
getvar
and all were indeed lowercase except mine.
So it seems that I need to update their LogInName to be uppercase as the variable LogInName is read only. Or change the result of tagname1 after it's populated.
Logged
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
Administrator
Seagull
Re: Correct me if I'm wrong...but strcase sets case
Reply #1 on:
July 28, 2021, 06:08:33 PM »
(strcase "Sample" T)
Specifying the
witch
as
true
will convert the string to lower case.
...click on the strcase function in your code block above to get the help for the function.
Logged
TheSwamp.org
(serving the CAD community since 2003)
jlogan02
Bull Frog
Reply #2 on:
July 28, 2021, 06:17:14 PM »
I did exactly that before I wrote the OP. It's clear to me, I read the help wrong.
Thanks for pointing that out,.
Logged
J. Logan
ACAD 2018
Seagull
London, England
WWW
Reply #3 on:
July 30, 2021, 01:03:46 PM »
Note that you are applying
strcase
to the attribute
tag
as returned by
vla-get-tagstring
in order to use a case-insensitive match between the attribute tag and the value held by the variable
tagname1
, not to the value that is used to populate the attribute.
I might suggest the following changes:
[Select]
setq
tag
"DESIGNER"
if
setq
sel
ssget
"_X"
0
"INSERT"
2
"TBLK_ATT_CTL"
66
1
repeat
setq
idx
sslength
sel
setq
idx
1-
idx
obj
vlax
ename
vla-object
ssname
sel idx
vl-some
lambda
att
if
and
tag
strcase
vla-get-tagstring
att
vlax-write-enabled-p
att
not
vla-put-textstring
att
strcase
substr
getvar
'loginname
1
3
t
vlax-invoke
obj 'getattributes
Here:
(0 . "INSERT")
is included in the ssget filter list
vl-some
will cease evaluation of the attributes when the target attribute is found
An
if
statement is used to verify that a valid selection exists
checks that the attribute can be modified (i.e. does not reside on a locked layer) prior to modification
Logged
Lee Mac Programming
Twitter
Exchange App Store
Print
Pages: [
1
Go Up
« previous
next »
Code Red
Topic:
