Author Topic: Check the field of the attribute  (Read 2352 times)
jasonwebster
  • Mosquito
« on: July 13, 2021, 11:44:55 PM »
The Best Robot Vacuums to Consider In 2020: Short Reviews
Robot vacuums are the newest trend in the vacuum cleaning industry. Understanding that automation is the future, a lot of best vacuum brands have invested money and effort into developing their own automated The Best Vacuum Cleaners, which promise to remove the chore of house cleaning from your daily life completely.
With their advanced sensor suite and a vast array of brushes, as well as powerful suction power, one of the following robot vacuums might be the best investment you will make for your home this year.
1. iRobot S9 Plus
If you want the most cutting-edge, best vacuum on the market, then the iRobot S9 Plus is the way to go. Even though it has a dizzying price tag, the cleaning performance, the smart navigation capability, and the ease of use make it completely worth it if you have the extra cash to spare.
In terms of performance, the suction power that is generated by the electric motor inside of this robot can suck up virtually everything in its way. On hardwood floors and carpets alike, we have found that the S9 Plus did brilliantly. The vacuum managed to suck out about ¾ of the sand we sprinkled into medium-pile carpets, which is quite amazing considering how the majority of the robot vacuums on the market at the moment struggle with carpets.
It also deals well with pet hair and allergens, so this best rated vacuum will do nicely for the pet owners and allergy sufferers out there .
It’s equipped with smart control and is WiFi-enabled. The S9 Plus has a specialised app that you can download to turn your smartphone into a versatile remote. From the app, you can adjust all of its various settings, set timing schedules, as well as map out different rooms and floors in the house. With the mapping function, you can even set ‘keep out zones’ for rooms that you don’t want the bot to visit.
The cleaning time of the S9 Plus is great. It takes about 25 minutes for the vacuum to completely clean our living room.
The CleanBase docking station simultaneously acts as a charging point and automatic dumping ground. The bot is smart enough to realise when it is about to run out of charge and return to base. It will also empty out the dirty contents inside of its dust cup into a separate, disposable bag at the station to make the emptying process easier.
Visit This Site: Best Vacuum Cleaners Reviews
2. Neato Botvac D7 Connected
For those who are seeking a more budget-friendly option, the Neato Botvac D7 Connected is a nice alternative to consider. It has nearly the same performance level as the S9 Plus, with the notable difference being that it is significantly cheaper in comparison.
The performance of the D7 on hardwood floors is more or less the same as the S9 Plus, as it’s able to pick up nearly every type of particle such as sand and ash, as well as larger debris like cereal bits with little trouble. The D7 also performed very well (even slightly better!) than the S9 Plus on low-pile carpets and rugs. However, when it comes to thicker carpets and rugs beyond the medium-pile range, this is where the D7 draws the line and the S9 Plus shines.
It’s also not as good at picking up pet hair and such like the S9 Plus, but the navigation suite on the D7 is more efficient at programming cleaning paths. The bot can clean a greater area and do it more thoroughly due to the LiDAR sensor packed inside of the compact body.
It also features smart controls and can be monitored directly from your phone. It’s also compatible with virtual assistants like Google Assistant and Alexa.
Conclusion
Ending this short installment in our Best Rated Vacuum Cleaner reviews, we hope that you have found the best robotic vacuum you’ve been looking for!
« Last Edit: August 04, 2023, 02:37:41 AM by jasonwebster »
BIGAL
  • 40 + years of using Autocad
Re: Check the field of the attribute
« Reply #1 on: July 14, 2021, 03:59:55 AM »
Just get textstring for the attribute use VL, then wcmatch to look for a part string of a field like "%<\AcObjProp"
roy_043
  • BricsCAD 18
« Reply #2 on: July 14, 2021, 07:43:44 AM »
  1. ; (has-field-p (car (nentsel)))
  2. (defun has-field-p (ename)
  3.   (and
  4.     (setq extDict (cdadr (member '(102 . "{ACAD_XDICTIONARY") (entget ename))))
  5.     (dictsearch extDict "ACAD_FIELD")
  6.   )
  7. )
