Author Topic: Insert block and ask for scale  (Read 3352 times)
like_citrus
« on: June 12, 2021, 12:06:49 AM »
I have a few blocks inserted from a pull down menu, and wanted to scale them as the block is inserted. The scale is variable and the user inputs this when the block is inserted.
The code below inserts blocks but needs something to ask for a scale.
All the blocks, except for one can be scaled using the "SCALE" command if done manually. The Dimension block can't be scaled using "SCALE", it's adjusted manually from the Properties toolbar by changing "Dim scale overall".
The process used:
- Create a folder and save the AutoCAD source files and menu (MNU) file in there.
- Load the menu file using the command "CUILOAD".
- Link this to AutoCAD by including in Support File Search Path. Tools/Options/Files tab. Add folder to Support File Search Path.
- Have the LISP code load automatically using the command "APPLOAD". Add the file to the Startup Suite.
MENU CODE
***MENUGROUP=MENU_TEMPORARY
***POP110
**CTOPopAID_DYNAMIC_TEMPORARY
            [Temporary]
            [<-Leader]^C^C(BlockInsertAndScale "CAD_Leader");
            [<-Dimension]^C^C(BlockInsertAndScale "CAD_Dimension");
LISP
(defun BlockInsertAndScale (blkname)
    (command "_.-insert" (substr (strcat blkname "-" (menucmd "m=$(edtime,0,yymoddhhmmss)") "=" blkname) (+ (vl-string-position (ascii "_") blkname 1) 2)) pause 1 "" 0)
    (command "explode" "last")
BIGAL
  • 40 + years of using Autocad
Re: Insert block and ask for scale
« Reply #1 on: June 12, 2021, 06:23:31 PM »
try replacing pause with (getreal "Enter scale")
like_citrus
« Reply #2 on: June 12, 2021, 10:39:59 PM »
Thanks.
I did try it, something happened but it didn't work exactly.
There was this prompt in the command line: Specify insertion point or [Basepoint Scale X Y Z Rotate]
After typing in a value it just pasted the object. And it didn't paste in the location clicked on. Also I couldn't see a silhouette of the object before it was pasted like before.
    (command "_.-insert" (substr (strcat blkname "-" (menucmd "m=$(edtime,0,yymoddhhmmss)") "=" blkname) (+ (vl-string-position (ascii "_") blkname 1) 2)) (getreal "Enter scale") 1 "" 0)
     (setq blkname (getvar "dimscale"))
ribarm
  • Marko Ribar, architect
« Reply #3 on: June 12, 2021, 11:49:50 PM »
AFAIK, first pause is for specifying insertion point and not for speciying scale... So IMHO, you should leave first pause and replace 1 with (progn (initget 3) (getreal "\nEnter scale : "))...
M.R. on Youtube
like_citrus
« Reply #4 on: June 13, 2021, 03:16:19 AM »
Thanks, that actually works.
I think it will work for all the blocks except as expected, for the Dimension block.
With the Dimension block, the arrow, offset, etc. are no scaled for some reason. If it's done manually, it's adjusted from the Properties toolbar by changing "Dim scale overall".
    (command "_.-insert" (substr (strcat blkname "-" (menucmd "m=$(edtime,0,yymoddhhmmss)") "=" blkname) (+ (vl-string-position (ascii "_") blkname 1) 2)) pause (progn (initget 3) (getreal "\nEnter scale : ")) "" 0)
like_citrus
« Reply #5 on: June 14, 2021, 12:28:39 AM »
I'm struggling with the Dimension.
Rather than changing "Dim scale overall", would it be easier to change the following: "Arrow size", "Text height", "Text offset", "Dim scale linear".
Or alternatively, is there a setting in AutoCAD which when scaling dimensions, it changes the appearance. Or a setting in Dimension Styles?
BIGAL
« Reply #6 on: June 14, 2021, 08:57:10 PM »
Like most styles you could get at the style prior to adding say a dimension, a simpler way may be to use entmake a dimension where you set the sizes, not tested but entmake often ignores current settings.
like_citrus
« Reply #7 on: June 14, 2021, 09:54:15 PM »
OK thanks, how can that be done using LISP.
BIGAL
« Reply #8 on: June 14, 2021, 10:18:08 PM »
If you use VL you can get at a lot of the dimension variables eg (vla-put-arrowheadsize 10)
So if you wanted the arrows to be twice the size (setq arrow (* 2.0 (vla-get-arrowheadsize obj)) (vla-put-arrowheadsize arrow)
Make the dim command etc then use (setq obj (vlax-ename->vla-object  (entlast)) to get the last object the Dimension.
Use Dumpit pick a dimension it will reveal the property names, then a get and put to change.
like_citrus
« Reply #9 on: June 14, 2021, 10:33:50 PM »
Thanks I tried this to get started but still no good.
It actually stops other defuns in the same LISP file from running.
(defun TestForDim (blkname)
BIGAL
« Reply #10 on: June 14, 2021, 10:44:50 PM »
You said change a dim that was what I answered a block is totally different
(command "dim" "hor" (list 0 0) (list 10 0) (list 5 5)  ""  "exit")
(setq obj (vlax-ename->vla-object  (entlast)))
(setq arrow (* 2.0 (vla-get-arrowheadsize obj)))
(vla-put-arrowheadsize obj arrow)
like_citrus
« Reply #11 on: June 14, 2021, 10:51:14 PM »
OK thanks but I'm really lost.
I tried incorporating your code but can't get it to work.
Is my understanding correct: That the block is first inserted and then your code changes it?
BIGAL
« Reply #12 on: June 14, 2021, 11:33:58 PM »
A dimension is not a block, but a block can be made including a dimension, you need to post a dwg so can look at what you actually have.
« Reply #13 on: June 14, 2021, 11:38:45 PM »
Are you sure about that ? Name of dim: (2 . "*D###")
« Last Edit: June 14, 2021, 11:57:19 PM by ronjonp »
like_citrus
« Reply #14 on: June 14, 2021, 11:50:07 PM »
I thought I had attached a dimension file in the original post.
Please see attached.
