^P(or layer-toggle-freeze(load "layer-toggle-freeze.lsp"))(layer-toggle-freeze '("Viewports" "Work"))
;; LAYER group codes ;; ;; Group codes - Description;; ;; 100 - Subclass marker (AcDbLayerTableRecord);; ;; 2 - Layer name;; ;; 70 - Standard flags (bit-coded values):;; 1 = Layer is frozen; otherwise layer is thawed;; 2 = Layer is frozen by default in new viewports;; 4 = Layer is locked;; 16 = If set, table entry is externally dependent on an xref;; 32 = If both this bit and bit 16 are set, the externally ;; dependent xref has been successfully resolved;; 64 = If set, the table entry was referenced by at least ;; one entity in the drawing the last time the drawing ;; was edited. (This flag is for the benefit of AutoCAD ;; commands. It can be ignored by most programs that ;; read DXF files and need not be set by programs that ;; write DXF files);; ;; 62 - Color number (if negative, layer is off);; ;; 6 - Linetype name;; ;; 290 - Plotting flag. If set to 0, do not plot this layer;; ;; 370 - Lineweight enum value;; ;; 390 - Hard-pointer ID/handle of PlotStyleName object
