Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Help with double offset and hatch lisp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Help with double offset and hatch lisp (Read 1798 times)
PM
Guest
on:
May 21, 2021, 03:46:01 AM »
Hi . This code begin with an option .Double offset (0.5 -0.5) and (2.0 -2.0). I try to write it as (a -a) , i dont know if is wrong.
Then i want to select the layer 1 polylines and add a hatch between of then . The hatch must be in Layer1 with lw 0.05 and type ANSI31 with scale 0.1
The code is
Code - Auto/Visual Lisp:
[Select]
defun
c:test
a sel int ent
TEXTPAGE
princ
\n
princ
\n
princ
\n
progn
initget
"1 2"
setq
l
cond
getkword
\n
SELECT OFFSET:
1. OFFSET 0.5
2. OFFSET 2.0
"1"
if
eq
l
"1"
setq
a
0.5
if
eq
l
"2"
setq
a
2.0
COMMAND
"_layer"
"_m"
"LAYER1"
"_c"
"93"
"_lw"
"0.30"
and
or
tblsearch
"LAYER"
"LAYER2"
alert
"Layer name < LAYER2 > was not found in this drawing to continue!"
princ
\n
Select polygon <LAYER2 > to offset on two sides: "
setq
int
1
sel
ssget
"_X"
0
"LINE,*POLYLINE"
8
"LAYER2"
while
setq
int
1+
int
ent
ssname
sel int
foreach
off '
a
a
vla-put-layer
car
vlax-invoke
vlax
ename
vla-object
ent
'offset off
"LAYER1"
princ
vl-load-com
Can any one help ?
Last Edit: May 21, 2021, 10:09:52 AM by PM
Logged
kpblc
Bull Frog
Re: Help with double offset and hatch lisp
Reply #1 on:
May 21, 2021, 03:52:40 AM »
Change
[Select]
foreach
off '
a
a
to
[Select]
foreach
off
list
a
a
Logged
Sorry for my English.
PM
Guest
Reply #2 on:
May 21, 2021, 10:02:37 AM »
Hi kpblc. I did the change but the code is not working as double offset but only like one side offset. The other problem is how to add hatch inside the double offset.
[Select]
defun
c:test
a sel int ent
TEXTPAGE
princ
\n
princ
\n
princ
\n
progn
initget
"1 2"
setq
l
cond
getkword
\n
SELECT OFFSET:
1. OFFSET 0.5
2. OFFSET 2.0
"1"
if
eq
l
"1"
setq
a
0.5
if
eq
l
"2"
setq
a
2.0
COMMAND
"_layer"
"_m"
"LAYER1"
"_c"
"93"
"_lw"
"0.30"
and
or
tblsearch
"LAYER"
"LAYER2"
alert
princ
\n
Select polygon < LAYER2 > to offset on two sides: "
setq
int
1
sel
ssget
"_X"
0
"LINE,*POLYLINE"
8
"LAYER2"
while
setq
int
1+
int
ent
ssname
sel int
foreach
off
list
a
a
vla-put-layer
car
vlax-invoke
vlax
ename
vla-object
ent
'offset off
"LAYER1"
princ
vl-load-com
;end defun
Any options
Last Edit: May 21, 2021, 10:27:38 AM by PM
Logged
PM
Guest
Reply #3 on:
May 21, 2021, 11:02:15 AM »
I did a stupid solution but i dont know how to add the hatch
[Select]
defun
c:test
a sel int ent
TEXTPAGE
princ
\n
princ
\n
princ
\n
progn
initget
"1 2"
setq
l
cond
getkword
\n
SELECT OFFSET:
1. OFFSET 0.5
2. OFFSET 2.0
"1"
if
eq
l
"1"
c:test1
if
eq
l
"2"
c:test2
princ
vl-load-com
;end defun
defun
c:test1
a sel int ent
COMMAND
"_layer"
"_m"
"LAYER1"
"_c"
"93"
"_lw"
"0.30"
and
or
tblsearch
"LAYER"
"LAYER2"
alert
princ
\n
setq
int
1
sel
ssget
"_X"
0
"LINE,*POLYLINE"
8
"LAYER2"
while
setq
int
1+
int
ent
ssname
sel int
foreach
off '
0.5
0.5
vla-put-layer
car
vlax-invoke
vlax
ename
vla-object
ent
'offset off
"LAYER1"
princ
vl-load-com
;end defun
defun
c:test2
a sel int ent
COMMAND
"_layer"
"_m"
"LAYER1"
"_c"
"93"
"_lw"
"0.30"
and
or
tblsearch
"LAYER"
"LAYER2"
alert
princ
\n
setq
int
1
sel
ssget
"_X"
0
"LINE,*POLYLINE"
8
"LAYER2"
while
setq
int
1+
int
ent
ssname
sel int
foreach
off '
2.00
2.00
vla-put-layer
car
vlax-invoke
vlax
ename
vla-object
ent
'offset off
"LAYER1"
princ
vl-load-com
;end defun
Logged
kpblc
Bull Frog
Reply #4 on:
May 21, 2021, 01:31:54 PM »
[Select]
vl-load-com
defun
t1
selset offset_value loops hatch layer
if
and
type
setq
selset
vl
catch
all
apply
function
lambda
ssget
0
"*POLYLINE"
8
"layer2"
4
"<OR"
70
1
70
129
4
"OR>"
;_ end of lambda
;_ end of function
;_ end of vl-catch-all-apply
;_ end of setq
;_ end of type
'pickset
;_ end of =
type
setq
offset_value
vl
catch
all
apply
function
lambda
initget
"1 2"
cond
getkword
\n
Select offset value [1 - offset 0.5/2 - ossfet 2.0] <1> : "
t
"1"
;_ end of cond
;_ end of lambda
;_ end of function
;_ end of setq
;_ end of type
'str
;_ end of =
;_ end of and
progn
vla-startundomark
setq
adoc
vla-get-activedocument
vlax-get-acad-object
setq
layer
vla-add
vla-get-layers
adoc
"Layer1"
vla-put-color
layer
93
vla-put-lineweight
layer aclnwt030
setq
offset_value
cond
atoi
offset_value
1
0.5
atoi
offset_value
2
2.0
;_ end of cond
loops
mapcar
function
lambda
ent
vl-sort
mapcar
function
lambda
x
setq
x
car
vlax
safearray
list
vlax
variant-value
x
vla-put-layer
x
vla-get-name
layer
x
;_ end of lambda
;_ end of function
list
vla-offset
vlax
ename
vla-object
ent
offset_value
vla-offset
vlax
ename
vla-object
ent
offset_value
;_ end of list
;_ end of mapcar
function
lambda
a b
vla-get-area
a
vla-get-area
b
;_ end of vl-sort
;_ end of lambda
;_ end of function
lambda
tab item
repeat
setq
tab
nil
item
sslength
selset
;_ end setq
setq
tab
cons
ssname
selset
setq
item
1-
item
tab
;_ end of repeat
;_ end of lambda
;_ end of mapcar
;_ end of setq
foreach
item loops
setq
hatch
vla-addhatch
vla-get-modelspace
adoc
achatchpatterntypepredefined
"ANSI31"
:vlax-false
achatchobject
;_ end of vla-AddHatch
;_ end of setq
vla-appendouterloop
hatch
vlax-safearray-fill
vlax
make
safearray
vlax-vbobject
0
0
list
car
item
;_ end of vla-appendouterloop
vla-appendinnerloop
hatch
vlax-safearray-fill
vlax
make
safearray
vlax-vbobject
0
0
list
cadr
item
;_ end of vla-appendinnerloop
vla-evaluate
hatch
vla-update
hatch
vla-put-layer
hatch
vla-get-name
layer
;_ end of foreach
vla-endundomark
adoc
;_ end of progn
;_ end of if
princ
;_ end of defun
Logged
PM
Guest
Reply #5 on:
May 21, 2021, 03:26:42 PM »
Thank you kpblc
Logged
PM
Guest
Reply #6 on:
May 21, 2021, 03:54:49 PM »
Hi kpblc a last question. How to change pattetn scale to 0.1 and hatch linetype bylayer ?
Last Edit: May 21, 2021, 03:58:07 PM by PM
Logged
PM
Guest
Reply #7 on:
May 22, 2021, 02:37:23 AM »
Thans
kpblc
i fix it
Logged
Seagull
London, England
WWW
Reply #8 on:
May 22, 2021, 09:58:47 AM »
Another, from almost 10 years ago...
https://www.cadtutor.net/forum/topic/43291-hatch-of-closed-polylines-offset-from-user-designated-points/?tab=comments#comment-353466
Logged
Lee Mac Programming
Twitter
Exchange App Store
ScottMC
Newt
Reply #9 on:
May 23, 2021, 06:33:03 PM »
Just tried it and VLIDE'd to understand the oops.. NOT yet
Corrected by removing: 103, 106, 132,133,134 and adding
(command "-bhatch" "S" "L" "" "") at the end. oldies still work!
Thanks Much Lee - you keep me thinkin
Last Edit: May 23, 2021, 11:05:46 PM by ScottMC
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
