Author Topic: Relocate blocks in line based on position  (Read 877 times)
Coder
« on: May 19, 2021, 06:20:09 AM »
Hello guys.
I have received a drawing for Lighting Fixtures to work on but I noticed that they are not in line on X and Y.
Is there a way to relocate them based on position by row and column as in screen print below ?
I know that I can use properties palette but the problem that I have many Fixtures in one row and column and not only a few as in image below
Thank you.
framednlv
Re: Relocate blocks in line based on position
« Reply #1 on: May 19, 2021, 03:13:19 PM »
Erase all but one and do an array.
Coder
« Reply #2 on: May 19, 2021, 04:48:40 PM »
Sorry, that solution is not applicable for my current situation.
I need to know how to get blocks with the same X with tolerance factor then reposition them according to the average X value so they will not be moved far than their current positions.
And the same way with Y coordinate.
Hope my explanation is clear enough and I can elaborate the issue if needed.
Thanks.
