Author Topic: Sequence of tasks into AutoCAD command prompt  (Read 1206 times)
dibraz0rd
  • Mosquito
« on: April 23, 2021, 02:15:37 PM »
Hello there again!
I have 300+ lines of task sequences in AutoCAD that, when copied from Excel and pasted onto the AutoCAD' command line, draw six views automatically. The sequence is more like that:
POLYLINE
0,0
0,-45
930,-45
930,0
0,0
POLYLINE
0,1240
0,1285
930,1285
930,1240
0,1240
POLYLINE
930,0
975,0
975,1240
930,1240
930,0
POLYLINE
0,0
-45,0
-45,1240
0,1240
0,0
_ARC
_C
0,0
-45,0
0,-45
(keeps repeating for like 300+ lines)
Is there a way to create a VBA script that, when clicking on a button, automatically copy it and paste it onto the command prompt to draw it? If not, is there a way to "make it easier" in your point of view?
Hope someone helps :)
Thanks!
BIGAL
  • 40 + years of using Autocad
Re: Sequence of tasks into AutoCAD command prompt
« Reply #1 on: April 24, 2021, 06:14:34 AM »
Excel can take control of autocad so can draw objects directly look at this excel example macro.
Public Sub Opendwg()
    Dim acadApp As Object
    Dim acadDoc As Object
 'Check if AutoCAD application is open. If is not opened create a new instance and make it visible.
    On Error Resume Next
    Set acadApp = GetObject(, "AutoCAD.Application")
    If acadApp Is Nothing Then
        Set acadApp = CreateObject("AutoCAD.Application")
        acadApp.Visible = True
    End If
    'Check (again) if there is an AutoCAD object.
        MsgBox "Sorry, it was impossible to start AutoCAD!", vbCritical, "AutoCAD Error"
        Exit Sub
    End If
    On Error GoTo 0
    'If there is no active drawing create a new one.
    Set acadDoc = acadApp.ActiveDocument
    If acadDoc Is Nothing Then
        Set acadDoc = acadApp.Documents.Add
    End If
    On Error GoTo 0
    'Check if the active space is paper space and change it to model space.
    If acadDoc.ActiveSpace = 0 Then '0 = acPaperSpace in early binding
        acadDoc.ActiveSpace = 1     '1 = acModelSpace in early binding
    End If
Public Sub addline(x1, y1, z1, x2, y2, z2)
 ' Create the line in model space
    'Dim acadApp As Object
    'Dim acadDoc As Object
    Dim startpoint(0 To 2) As Double
    Dim endpoint(0 To 2) As Double
    Dim lineobj As Object
    startpoint(0) = x1: startpoint(1) = y1: startpoint(2) = z1
    endpoint(0) = x2: endpoint(1) = y2: endpoint(2) = z2
    Set lineobj = acadDoc.ModelSpace.addline(startpoint, endpoint)
    acadApp.ZoomExtents
    Public Sub addcirc(x1, y1, z1, rad)
 ' Create the circle in model space
   ' Dim acadApp As Object
   ' Dim acadDoc As Object
    Dim cenpoint(0 To 2) As Double
    Dim circobj As Object
   cenpoint(0) = x1: cenpoint(1) = y1: cenpoint(2) = z1
    Set circobj = acadDoc.ModelSpace.addcircle(cenpoint, rad)
    acadApp.ZoomExtents
    Sub addpoly(cords, col)
    Dim oPline As Object
' add pline to Modelspace
Set oPline = acadDoc.ModelSpace.AddLightWeightPolyline(cords)
oPline.Color = col
    Sub alan1()
' This example adds a line in model space
' Define the start and end points for the line
    px1 = 1
    px2 = 5
    py1 = 1
    py2 = 5
    pz1 = 0
    pz2 = 0
Call addline(px1, py1, pz1, px2, py2, pz2)
 Sub alan2()
    px1 = 1
    py1 = 1
    pz1 = 0
    Radius = 8.5
 Call addcirc(px1, py1, pz1, Radius)
 Sub alan3()
 'Dim coords(0 To n) As Double
 Dim coords(0 To 5) As Double
 coords(0) = -6: coords(1) = 1:
 coords(2) = 3: coords(3) = 5:
 coords(4) = 7.55: coords(5) = 6.25:
 col = 1
 Call addpoly(coords, col)
ribarm
  • Marko Ribar, architect
« Reply #2 on: April 24, 2021, 06:23:23 AM »
To me, this looks like a script (*.scr) file... Just save it as *.scr and run "SCRIPT" command and provide created *.scr file...
M.R. on Youtube
DEVITG
« Reply #3 on: April 26, 2021, 07:32:16 PM »
some like this SCR
 command is PLINE , not POLYLINE
PLINE
0,0
0,-45
930,-45
930,0
0,0
PLINE
0,1240
0,1285
930,1285
930,1240
0,1240
PLINE
930,0
975,0
975,1240
930,1240
930,0
PLINE
0,0
-45,0
-45,1240
0,1240
0,0
it give
DEVITG
« Reply #4 on: April 26, 2021, 07:33:18 PM »
the SCR file
