Honesty is required all the time even if we are hidden behind our screens.
Hello Tharwat,
Yes, I am an amateur but not that stupid.
You never reply me about the results in TEST63.dwg and TEST45.dwg... take the test and you will also know if your code works.
I tested your original code over 700 times and had about 3 bugs but didn't mind that much.
So, i added some small things such as gray dashed lines... and got of course the same bugs...
Also with new Windows and AutoCAD 2022 I have bugs with your
ORIGINAL code.
It is not my fault that your code does not work 100% in version 2022!
Don't wast your time on this kind of innuendo... it will never make your code work better.
You remain an expert in AutoLISP for me and I was able to learn a lot from your code, i have only lucky that my cocktail works well.
So again, thank you very much for your hard work.
Christina
