Author Topic: Routine requires an enter between picks.  (Read 4359 times)
jlogan02
« on: January 12, 2021, 11:22:09 AM »
I'm trying to change overridden dimensions from their overridden color to another color. Not change the dimstyle, just the dims placed in the drawing.
The dimoverride command runs and allows me to pick the dimensions. It changes them just fine but doesn't move onto the next ssget without me hitting enter, but it works fine.
Now that I write that, that sounds like normal operation since I want the user to pick the objects that need to change. Can someone verify that for me?
I don't know...
If I switch them around the ssget col
for text, lines, and etc. runs then gives me the pickbox for the dims but won't actually pick the dims.
  1. (defun c:test (/ col col1 )
  2.
  3.  (while (if (setq col1 (ssget "_:L" '((0 . "dimension"))))
  4.     (command "_.dimoverride" "dimclrd" 1 "dimclre" 1 "dimclrt" 1 "" col1 "")
  5.     )
  6.    )
  7.
  8.   (setq col (ssget "_:L" '((0 . "MultiLeader,Hatch,*Line,*Text,Arc,Circle"))))
  9.         (foreach x (mapcar 'cadr (ssnamex col))
  10.         (entmod (append (entget x) '((62 . 1)))))
  11.
  12.
  13.   (princ)
  14. )
Any ideas.
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
Tharwat
  • Hypersensitive
Re: Routine requires an enter between picks.
« Reply #1 on: January 12, 2021, 01:36:20 PM »
  1. (defun c:test (/ col lst)
  2.   (if (setq col (ssget "_:L" '((0 . "MultiLeader,Hatch,*Line,*Text,Arc,Circle,dimension"))))
  3.     (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex col)))
  4.       (if (= (strcase (cdr (assoc 0 (setq lst (entget x))))) "DIMENSION")
  5.         (command "_.dimoverride" "dimclrd" 1 "dimclre" 1 "dimclrt" 1 "" (ssadd x) "")
  6.         (entmod (append lst '((62 . 1))))
  7.         )
  8.       )
  9.     )
  10.   (princ)
  11. )
  12.
jlogan02
« Reply #2 on: January 14, 2021, 01:47:20 PM »
  7.         )
  8.       )
  9.     )
  10.   (princ)
  11. )
  12.
Thanks Tharwat,
Am I understanding the
correctly. It's adding all entities found in
  1. setq col
to the selection of dimoverride, and then entmoding those selections found for that selection?
So in effect using the opportunity given by the user prompt for selecting dims during the dimoverride?
J. Logan
ACAD 2018
Tharwat
  • Hypersensitive
« Reply #3 on: January 14, 2021, 01:56:11 PM »
No, the ssadd function converts an entity to selection set and it is only for the dimension objects in this case although I think it would work without converting the entity to selection which means that you can replace the (ssadd x) with just the variable 'x' .
Entmod is used for all the object names that are included in the filter with ssget except the dimensions.
jlogan02
« Reply #4 on: January 15, 2021, 05:18:14 PM »
Dropping the
does indeed work. Thanks.
I have several versions of this to make. The next version would select all objects colored RED and change them to 56. Each subsequent version would do the same, color 56 to 136, 136 to 191, 191 to 107.
so...RED to color 56
  1.  (if (setq col (ssget "_X" '((62 . 1)(0 . "MultiLeader,Hatch,*Line,*Text,Arc,Circle,dimension"))))
  2.     (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex col)))
  3.       (if (= (strcase (cdr (assoc 0 (setq lst (entget x))))) "DIMENSION")
  4.         (command "_.dimoverride" "dimclrd" 56 "dimclre" 56 "dimclrt" 56 "" (ssadd x) "")
  5.         (entmod (append lst '((62 . 56))))
  6.        )
  7.      )
  8.    )
Changed
  1. (setq col (ssget "_:L" '((0 . "MultiLeader,Hatch,*Line,*Text,Arc,Circle,dimension"))))
to
  1. (setq col (ssget "_X" '((62 . 1)(0 . "MultiLeader,Hatch,*Line,*Text,Arc,Circle,dimension"))))
;;;get all red objects
and changed the color numbers from
  1. (command "_.dimoverride" "dimclrd" 1 "dimclre" 1 "dimclrt" 1 "" (ssadd x) "")
  2.         (entmod (append lst '((62 . 1))))
to
  1. (command "_.dimoverride" "dimclrd" 56 "dimclre" 56 "dimclrt" 56 "" (ssadd x) "")
  2.         (entmod (append lst '((62 . 56))))
Either I've dropped something and am not seeing it. Or I'm missing code and don't know it.
If I leave out the (62 . 1) from the code it changes everything including objects I don't want changed. If I include (62 . 1) it changes all red objects to color 56 but dimensions.
J. Logan
ACAD 2018
Tharwat
  • Hypersensitive
« Reply #5 on: January 15, 2021, 05:33:31 PM »
Your mods should work without any issue I believe.
But the objects that didn't change to the new color 56 may were on Red color by layer and if so, then you need to go with different selection set by iterating the layer table and get the layer names that set with red color then add the list into the filter of the selection set.
Difficult?  :no:
jlogan02
« Reply #6 on: January 15, 2021, 05:51:51 PM »
Let me verify that and get back to you.
J. Logan
ACAD 2018
jlogan02
« Reply #7 on: January 15, 2021, 06:03:52 PM »
Drew an line on a layer with layer color set to red - Fail.
Drew a line on a layer and changed the lines color property to red using the code you helped me with earlier - Success.
Did the same with a dimensions.
Dim on Layer with layer color set to red - failed.
Dim on Layer with overridden dimclrt, dimclre, dimclrd to red - failed.
We have one layer that uses color bylayer RED. I can deal with that.
J. Logan
ACAD 2018
jlogan02
« Reply #8 on: January 15, 2021, 06:06:54 PM »
Full code
  1. (defun c:ST01to56 (/ *error* col lst osm )
  2.   (defun _addlayer (name color ltype plot)
  3.     (cond ((not (tblsearch "layer" name))
  4.            (entmakex (list '(0 . "LAYER")
  5.                            '(100 . "AcDbSymbolTableRecord")
  6.                            '(100 . "AcDbLayerTableRecord")
  7.                            '(70 . 0)
  8.                            (cons 2 name)
  9.                            (cons 62 color)
  10.                            (cons 6
  11.                                  (cond ((tblobjname "ltype" ltype))
  12.                                        ("continuous")
  13.                                  )
  14.                            )
  15.                            (cons 290 plot)
  16.                            ;;1 = plottable 0 = not=plottable
  17.                      )
  18.            )
  19.           )
  20.           ((tblobjname "layer" name))
  21.     )
  22.   )
  23.   (defun *error* (msg)
  24.     (if osm
  25.       (setvar 'osmode osm)
  26.     )
  27.     (if (not (member msg '("Function cancelled" "quit / exit abort")))
  28.       (princ (strcat "\nError: " msg))
  29.     )
  30.     (princ)
  31.   )
  32.   (setq osm (getvar 'osmode))
  33.   (setvar 'osmode 0)
  34.   (setvar 'cmdecho 0)
  35.
  36.   (if (setq col (ssget "_X" '((0 . "MultiLeader,Hatch,*Line,*Text,Arc,Circle,dimension")(62 . 1))))
  37.     (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex col)))
  38.       (if (= (strcase (cdr (assoc 0 (setq lst (entget x))))) "DIMENSION")
  39.         (command "_.dimoverride" "dimclrd" 56 "dimclre" 56 "dimclrt" 56 "" (ssadd x) "")
  40.         (entmod (append lst '((62 . 56))))
  41.        )
  42.      )
  43.    )
  44.
  45.   (_addlayer "FiberMgt_056" 56 "Continous" 1)
  46.
  47.   (if (setq fm1 (ssget "x" '((8 . "FiberMgt_001"))))
  48.     (foreach x (mapcar 'cadr (ssnamex fm1))
  49.        (entmod (append (entget x) '((8 . "FiberMgt_056"))))
  50.     )
  51.   )
  52.
  53.     ;;(command ".-layer" "filter" "edit" "Stations Standard Layers" "add" "FiberMgt_056" "exit" "")
  54.
  55.
  56.   (if (tblsearch "LAYER" "FiberMgt_001")
  57.     (command "-laydel" "_n" "FiberMgt_001" "" "Y" "")
  58.   )
  59.
  60.   (command ".-layer" "filter" "edit" "Stations Standard Layers" "add" "FiberMgt_056" "exit" "")
  61.
  62.   (setvar 'osmode osm)
  63.   (setvar 'cmdecho 1)
  64.
  65.   (princ)
  66. )
J. Logan
ACAD 2018
Tharwat
  • Hypersensitive
« Reply #9 on: January 16, 2021, 06:47:23 AM »
Rectify this:
  1.  (mapcar 'cadr (ssnamex fm1))
With this:
  1. (vl-remove-if 'listp (mapcar 'cadr (ssnamex fm1)))
  2.
« Reply #10 on: January 16, 2021, 11:00:33 PM »
Rectify this:
With this:
  2.
@Tharwat you don't need the vl-remove-if when "_X" is used in ssget.
Tharwat
  • Hypersensitive
« Reply #11 on: January 17, 2021, 03:53:41 AM »
Thanks Ron, you are right.
But what makes that difference once using that string mode in your opinion ?
Tharwat
  • Hypersensitive
« Reply #12 on: January 17, 2021, 03:55:35 AM »
Logan,
Please upload the same drawing that you tested your codes out on to take a close look if possible.
« Reply #13 on: January 18, 2021, 02:34:47 PM »
I'm not sure I understand your question.
Tharwat
  • Hypersensitive
« Reply #14 on: January 18, 2021, 02:45:09 PM »
Once using the ssget "_X" then there is no need to use (vl-remove-if 'listp ... but with the ssget "_:L" for instance there is a need to use (vl-remove-if 'listp  since the return of the ssnamex would return the last item in the list as a list.
I have read about ssget and ssnamex functions and nothing was written in regard of such a return or so.
