Author Topic: Could somebody check me here ???  (Read 1396 times)
jlogan02
« on: November 12, 2020, 05:25:54 PM »
It doesn't restore the current layer setting
It doesn't restore the Dimstyle.
  1. (defun c:STA_DIMEN ( / )
  2. (setvar "filedia" 0)
  3. (setvar "osmode" 129)
  4. (setvar "dimclrt" 1)
  5. (setvar "dimclre" 1)
  6. (setvar "dimclrd" 1)
  7. (command "-Dimstyle" "Save" "DimenRed")
  8. (setq Clay (getvar "CLAYER"))
  9. (command "-layer" "M" "DIMEN" "")
  10. (command "dimlinear")
  11. (command "-dimstyle" "R" "DIMEN")
  12. (setvar "CLAYER" Clay)
  13. (setvar "filedia" 1)
  14.   (princ
  15. )
  16.   )
Probably going about it completely wrong.
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
kpblc
Re: Could somebody check me here ???
« Reply #1 on: November 12, 2020, 11:43:46 PM »
You didn't finish command _.dimlinear. Try to change
  1. (command "_.dimlinear")
to
  1. (command "_.dimlinear" pause pause pause)
And you didn't check are dimstyles DimenRed and DIMEN really exist in current drawing.
Sorry for my English.
MatGrebe
  • Mosquito
« Reply #2 on: November 13, 2020, 02:00:45 AM »
And
to
(command "-dimstyle" "R" "DimenRed")
Mathias
HasanCAD
« Reply #3 on: November 13, 2020, 09:48:53 AM »
(defun c:STA_DIMEN ( / fd om dt de dd clay )
  (setq fd (getvar "filedia")) (setvar "filedia" 0)
  (setq om (getvar "osmode"))  (setvar "osmode" 129)
  (setq dt (getvar "dimclrt")) (setvar "dimclrt" 1)
  (setq de (getvar "dimclre")) (setvar "dimclre" 1)
  (setq dd (getvar "dimclrd")) (setvar "dimclrd" 1)
  (setq Clay (getvar "CLAYER")) (command "-layer" "M" "DIMEN" "")
 ; (command "dimlinear")
  ;(command "-dimstyle" "R" "DIMEN")
  (setvar "filedia" fd)
  (setvar "osmode" om)
  (setvar "dimclrt" dt)
  (setvar "dimclre" de)
  (setvar "dimclrd" dd)
jlogan02
« Reply #4 on: November 13, 2020, 12:23:21 PM »
Thanks guys,
to
I realized very early this morning that I should probably check if they exist. Pause Pause Pause. Crap!!!
And
to
Mathias
I am indeed trying to reset the dimstyle back to "DIMEN" which is the default. The save action sets the saved dimstyle current as desired. However, I think it best just two make to buttons, one that checks for each dimstyle and then sets it current. Rather than my approach.
Thanks Hasan,
Yes, resetting saving and resetting would be a better approach. This way there is no error factor possible.
Thanks again guys.
J. Logan
ACAD 2018
