(COMMAND "Layout" "COPY" "Layout1" "1")(COMMAND "Layout" "SET" "Layout1")
Excellent! Thank you for the clarification on it! I really appreciate it!
Just want to clarify, if layout1 is copied 8 times, and then renamed to layout1, layout2, etc. it will still go back to layout1.
; GOTO layout just like other goto a page; By Alan H 2013; menu command [GOTO]^c^C^p(load "goto"); enter a big number like 99 to jump to last if 100+ layouts then 123 etc; Model space is 0 zero GOTO 0(defun C:goto ( / x alllayouts laynum num)(setq num (getint "Enter layout number" ))(setq alllayouts (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object))))(SETQ LAYNUM 0)(vlax-for x alllayouts(Setq laynum (+ 1 laynum))) ;total number of layouts(if (> num laynum)(setq num (- laynum 1)))(vlax-for lay alllayouts(if (= num (vla-get-taborder lay))(setvar "ctab" (vla-get-name lay))))); I often type it wrong so added this one also(defun C:goot ()(c:goto)) ; defun
(setq laynum (length (layoutlist)))
You cannot run the "pp_bigalayout_jspin15.lsp" without "Password PinAcces=6548"
Not a problem. I did not want to get to far ahead of myself! lol Thank you for the advice.
