Author Topic: Activate the first Layout Tab  (Read 1982 times)
MSTG007
« on: September 24, 2020, 08:44:17 AM »
I know this is a dumb one to ask for. I am having a hard time figuring out how to activate the first layout tab in a current dwg. I have a routine that will make X copies of the current layout tab, usually it will end at the last layout tab. I was wondering how to get it back to the first layout tab.
Thanks guys for pointing me in the right direction.
Civil3D 2020
HOSNEYALAA
Re: Activate the first Layout Tab
« Reply #1 on: September 24, 2020, 08:55:21 AM »
(COMMAND "Layout" "COPY" "Layout1" "1")
(COMMAND "Layout" "SET" "Layout1")
Tharwat
  • Hypersensitive
« Reply #2 on: September 24, 2020, 09:00:24 AM »
  1. ;; assign the name of the current layout before running your codes.
  2. (setq cur (getvar 'CTAB))
  3. ;; your codes that doing some stuff here .....
  4. ;; Reset or back to original layout.
  5. (setvar 'CTAB cur)
  6.
MSTG007
« Reply #3 on: September 24, 2020, 10:01:07 AM »
Would this code be generic enough for any named layout tab or does it have to be specific to use?
Civil3D 2020
Tharwat
  • Hypersensitive
« Reply #4 on: September 24, 2020, 10:35:53 AM »
Regardless of your active layout name you are on.
MSTG007
« Reply #5 on: September 24, 2020, 10:42:19 AM »
Excellent! Thank you for the clarification on it! I really appreciate it!
Civil3D 2020
Tharwat
  • Hypersensitive
« Reply #6 on: September 24, 2020, 10:44:15 AM »
You're welcome anytime.
alanjt
  • Standby for witty remark...
« Reply #7 on: September 24, 2020, 11:18:48 AM »
Keep in mind, this works as long as you don't change the name of the layout tab while the program is running.
Dropbox
MSTG007
« Reply #8 on: September 24, 2020, 11:59:55 AM »
Just want to clarify, if layout1 is copied 8 times, and then renamed to layout1, layout2, etc. it will still go back to layout1.
Civil3D 2020
Tharwat
  • Hypersensitive
« Reply #9 on: September 24, 2020, 12:06:36 PM »
Try to do it yourself to learn from what you come up with your codes, and such practices you would be remember for a long time so this is one of the best ways to be good at coding.
MSTG007
« Reply #10 on: September 24, 2020, 12:09:17 PM »
Not a problem. I did not want to get to far ahead of myself! lol Thank you for the advice.
Civil3D 2020
BIGAL
  • 40 + years of using Autocad
« Reply #11 on: September 28, 2020, 11:14:59 PM »
I wrote this as there is no "goto" a layout, like Word has goto page x.
It has the answer to your problem.
; GOTO layout just like other goto a page
; By Alan H 2013
; menu command [GOTO]^c^C^p(load "goto")
; enter a big number like 99 to jump to last if 100+ layouts then 123 etc
; Model space is 0 zero GOTO 0
(defun C:goto ( / x alllayouts laynum num)
(setq num (getint  "Enter layout number" ))
(setq alllayouts (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object))))
(SETQ LAYNUM 0)
(vlax-for x alllayouts
(Setq laynum (+ 1 laynum))
) ;total number of layouts
(if (> num laynum)
(setq num (- laynum 1))
(vlax-for lay alllayouts
(if (= num (vla-get-taborder lay))
(setvar "ctab" (vla-get-name lay))
; I often type it wrong so added this one also
(defun C:goot ()
(c:goto)
) ; defun
d2010
« Reply #12 on: September 29, 2020, 07:01:10 AM »
You get maxLayouts with thiscode
(setq laynum (length (layoutlist)))   :wideeyed2:
You cannot run the "pp_bigalayout_jspin15.lsp"
without "Password PinAcces=6548"
« Last Edit: September 29, 2020, 07:17:55 AM by d2010 »
