Code Red > .NET
Transient graphics not showing Text
ROYNIJKAMP:
I am displaying a temporary line between 2 picked polylines.
The line is showing as expected execept for the Text object.
I have tried to add a Text to the Transient Graphics, but is it not showing.
Why is the Text not showing, is it not possible to show the text on the Fly?
Below the code i use.
--- Code - vb.net: ---Public Class clsMarkerLine Private Shared plStart As Polyline Private Shared plEind As Polyline Private Shared m_markers As DBObjectCollection = New DBObjectCollection() Private Shared collectints As IntegerCollection = New IntegerCollection() Public Shared Sub StartMarker(ByVal polyStart As Polyline, ByVal polyEind As Polyline) Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor AddHandler ed.PointMonitor, New PointMonitorEventHandler(AddressOf ed_PointMonitor) plStart = polyStart plEind = polyEind End Sub Public Shared Sub StopMarker() Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor ed.TurnForcedPickOn() RemoveHandler ed.PointMonitor, New PointMonitorEventHandler(AddressOf ed_PointMonitor) ClearMarkers() End Sub Private Shared Sub ed_PointMonitor(ByVal sender As Object, ByVal e As PointMonitorEventArgs) showLine(e.Context.RawPoint) End Sub Private Shared Sub showLine(ByVal pt As Point3d) ClearMarkers() 'marker line Dim myLine As Line = dynLine(pt) m_markers.Add(myLine) aGi.TransientManager.CurrentTransientManager.AddTransient(myLine, aGi.TransientDrawingMode.DirectShortTerm, 128, collectints) 'marker text Dim myText As DBText = dynLineLengthText(pt, myLine) m_markers.Add(myText) aGi.TransientManager.CurrentTransientManager.AddTransient(myText, aGi.TransientDrawingMode.DirectShortTerm, 128, collectints) End Sub Public Shared Function dynLine(pt As Point3d, Optional sLayer As String = "0") As Line Dim myLine As Line = New Line() myLine.StartPoint = pt myLine.EndPoint = plStart.GetClosestPointTo(pt, True) Dim pts As New Point3dCollection() myLine.IntersectWith(plEind, Intersect.ExtendThis, pts, New IntPtr(0), New IntPtr(0)) If pts.Count > 0 Then myLine.StartPoint = pts(0) End If myLine.Layer = sLayer myLine.ColorIndex = 10 dynLine = myLine End Function Public Shared Function dynLineLengthText(pt As Point3d, ln As Line, Optional sLayer As String = "0") As DBText Dim acText As DBText = New DBText() Dim dStart As Double = (ln.StartPoint.X + ln.EndPoint.X) / 2 Dim dEind As Double = (ln.StartPoint.Y + ln.EndPoint.Y) / 2 Dim ptCenter As Point3d = New Point3d(dStart, dEind, 0) Dim CustomLineParmameters As CustomLineParam = getCustomLineParam(ln, ptCenter, True, False, 0.0, 0.5) Dim newAngle As Double = CustomLineParmameters.Angle acText.Rotation = newAngle * Math.PI / 180 acText.TextString = Math.Round(CustomLineParmameters.LineLength, 2).ToString & " m" acText.Position = CustomLineParmameters.Point acText.Layer = sLayer acText.ColorIndex = 10 dynLineLengthText = acText End FunctionEnd Class
n.yuan:
--- Quote from: ROYNIJKAMP on June 11, 2020, 07:25:19 AM ---
--- Code - vb.net: ---Public Class clsMarkerLine ... Private Shared collectints As IntegerCollection = New IntegerCollection() ... Private Shared Sub showLine(ByVal pt As Point3d) ClearMarkers() 'marker line Dim myLine As Line = dynLine(pt) m_markers.Add(myLine) aGi.TransientManager.CurrentTransientManager.AddTransient(myLine, aGi.TransientDrawingMode.DirectShortTerm, 128, collectints) 'marker text Dim myText As DBText = dynLineLengthText(pt, myLine) m_markers.Add(myText) aGi.TransientManager.CurrentTransientManager.AddTransient(myText, aGi.TransientDrawingMode.DirectShortTerm, 128, collectints) End Sub ... End Class
--- End quote ---
I think the issue lies in the argument of IntegerCollection passed into AddTransient() method: you need to pass a new/empty IntegerCollection, not one shared by multiple calls, like:
TransientManager.AddTransient(myLine, aGi.TransientDrawingMode.DirectShortTerm, 128, new IntegerCollection())
TransientManager.AddTransient(myText, aGi.TransientDrawingMode.DirectShortTerm, 128, new IntegerCollection())
huiz:
I am not sure if it is impossible but I had only success with shx fonts, not with ttf fonts.
Jeff_M:
I have always used the single IntergerCollection for any number of objects to be displayed, Norman.
If the text style used is a TrueType font, trying changing to one that uses an SHX font. I seem to recall having issues with TT fonts in TransientGraphics. huiz beat me to this.
n.yuan:
--- Quote from: Jeff_M on June 11, 2020, 01:29:04 PM ---I have always used the single IntergerCollection for any number of objects to be displayed, Norman.
--- End quote ---
Good to know, Jeff. Thanks.
Navigation
[0] Message Index
[#] Next page
Go to full version
