CAD Forums > CAD General
dwg shortcut on different versions of AutoCAD
dubb:
I want to create a dwg shortcut that executes a script. I can only find examples of Target strings where it needs to contain the exact location of acad.exe
Here is an example of a Target string that works.
--- Code: ---"C:\Program Files\Autodesk\AutoCAD 2018\acad.exe" /t "\\server\cad\00_Templates\blank.dwg" /b "\\server\cad\10_CAD Support\Scripts\foo-script"
--- End code ---
Is there a way to edit the Target string so that I don't need to define the exact location of acad.exe?
I tried this. It didn't work.
--- Code: ---"\\server\cad\00_Templates\blank.dwg" /b "\\server\cad\10_CAD Support\Scripts\foo-script"
--- End code ---
ronjonp:
Not exactly sure what you're asking but shouldn't this need the file extension to work?
"\\server\cad\10_CAD Support\Scripts\foo-script.scr"
dubb:
Surprisingly it works with or without the .scr file extension.
--- Quote from: ronjonp on May 21, 2020, 05:06:13 PM ---Not exactly sure what you're asking but shouldn't this need the file extension to work?
--- End quote ---
I was thinking about adding a cmd string to access the registry to get the default acad.exe directory followed by
--- Code: ---/t "\\server\cad\00_Templates\blank.dwg" /b "\\server\cad\10_CAD Support\Scripts\foo-script"
--- End code ---
dubb:
I tried loading the script using "command script". Still doesn't work.
--- Code: ---"\\server\cad\00_Templates\blank.dwg" (command "SCRIPT" "\\\\server\\cad\\10_CAD Support\\Scripts\\foo-script.scr")
--- End code ---
ronjonp:
Are you adding this to the autocad shortcut? Not sure where you're going with the command ?
Navigation
[0] Message Index
[#] Next page
Go to full version
