Author Topic: autocad location  (Read 3344 times)
civil.eng
autocad location
« on: April 22, 2020, 01:39:08 AM »
Hi all,
in a project with inno setup I need to get Acad.exe installed location. I tried with FileSearch but it doesn't work, I know we can find the path with windows registry, does anyone have information about it?
BIGAL
  • 40 + years of using Autocad
Re: autocad location
« Reply #1 on: April 22, 2020, 01:50:18 AM »
Just look at the toolbar icon properties on the desktop for the location.
civil.eng
« Reply #2 on: April 22, 2020, 05:00:43 AM »
Your way work only on my system, What about the other systems? I need to find location with any version of autocad and windows in inno setup.
Dlanor
« Reply #3 on: April 22, 2020, 07:04:51 AM »
Try
  1. (findfile "acad.exe")
roy_043
  • BricsCAD 18
« Reply #4 on: April 22, 2020, 01:05:11 PM »
Start digging from here:
HKEY_CLASSES_ROOT\.dwg
civil.eng
« Reply #5 on: April 22, 2020, 06:37:28 PM »
Try
This is not a logical solution,because FindFile method will search all file of system, while I think we can extract it from registry windows easily,
Dlanor
« Reply #6 on: April 22, 2020, 07:06:51 PM »
Try
It's perfectly logical. AutoCAD knows where it is installed, and findfile will only search in the current AutoCAD search paths, one of which will be where it is installed.
dgorsman
« Reply #7 on: April 22, 2020, 08:17:05 PM »
There is a registry key under HKLM which has the install location, you just need to look for it.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
snownut2
  • Bricscad 22 Ultimate
« Reply #8 on: April 22, 2020, 09:04:13 PM »
EmiCad has a utility that runs from Innosetup, and ask user which instance on CAD to install for.  Works for both A AD and BricsCad.  I can get you details tomorrow, I use it very successfully.
« Reply #9 on: April 22, 2020, 09:44:30 PM »
« Reply #10 on: April 22, 2020, 10:08:48 PM »
Please note that amir0914 is using inno setup; not AutoCAD/Autolisp.
- John Carmack
- J.R.R. Tolkien
« Reply #12 on: April 23, 2020, 09:43:44 AM »
Ahhh. Apologies to Amir. Findfile is the wrong tool outside AutoCAD; inside AutoCAD it would be totally legit.
Dlanor
« Reply #13 on: April 23, 2020, 01:42:07 PM »
Oops. My apologies. :opps:
