Author Topic: Poly in poly?  (Read 2437 times)
mohobrien
Poly in poly?
« on: June 15, 2005, 12:45:44 PM »
I've been using a simple routine to check if I have a polygon inside another polygon. Just lately, I've noticed that it has been falling down on the job. This is a stripped down version with some extraneous stuff left in that I use. Is there a problem with ssget with "wp" or am I doing something wrong.
(defun c:polyinside (/)
  (setq entity (car (entsel "\nPick a polygon to check: ")))
  (setq wp (LWPolylineInfo entity))
  (if (equal (car wp) (last wp))
;make sure first vertex = last vertex
    (setq closedwp wp)
    (setq closedwp (append wp (list (car wp))))
  (setq ;check to see if there are any inner rings
    innerss (ssget
     "wp"
     closedwp
     (list (cons 0 "LWPOLYLINE"))
  (if innerss
    (princ "Yes")
    (princ "No")
;; most of this routine courtesy of Rakesh Rao at 4dTechnologies
(defun LWPolylineInfo (ename /   wp     entitylist
      len n   e1
      windowpolygon   coords    xcoord
      ycoord
  (setq
    entitylist (entget ename) ;get the entity list
    len       (length entitylist) ;get the length of the list
    n       0 ;set counter to zero
  (repeat len ;repeat for the length of the entity list
    (setq e1 (car (nth n entitylist))) ;get each item in the entity list
;and strip the entity code number
    (if (= e1 10) ;check for code 10 (vertex)
      (progn ;if it's group 10 do the following
(setq coords (cdr (nth n entitylist)))
;get the vertex (a list)
(setq windowpolygon (append windowpolygon coords))
(setq xcoord (car coords)) ;get the xcoord
(setq ycoord (cadr coords)) ;get the y coord
      ) ;progn
    ) ;if
    (setq n (1+ n)) ;increment the counter to get next polyline
  ) ;repeat
  (setq wp (xyList->ListOfPoints windowpolygon))
It works with some polygons but not others.
http://www.theswamp.org/lilly_pond/mohobrien/north.wmf?nossi=1
The polygons on the left find the interior polygons, the one on the right does not.
mohobrien
Poly in poly?
« Reply #1 on: June 15, 2005, 06:00:57 PM »
Found the cause in case any body else has the same problem. The polygon that the routine didn't work on had a double vertex. Once that was removed it found the inner polygon. Anyone know why that would be the case?
Poly in poly?
« Reply #2 on: June 15, 2005, 07:12:04 PM »
What is a double vertex?
Are you talking about two vertex at the same point?
mohobrien
Poly in poly?
« Reply #3 on: June 15, 2005, 09:16:43 PM »
yes
Poly in poly?
« Reply #4 on: June 15, 2005, 09:55:46 PM »
I am cofused by your  LWPolylineInfo routine.
You did not post the xyList->ListOfPoints routine.
Why are you getting the xcoord & ycoord ?
mohobrien
Poly in poly?
« Reply #5 on: June 15, 2005, 10:08:01 PM »
The routine I posted was part of a larger routine I use to convert some of my polygon layers to esri shape files. I just stripped out parts to make the small routine I posted. I didn't clean it up much and so that's where the unused functions come from. I posted the whole routine once. I can't remember if it was here or cadvault but never had any interest or feedback so didn't want to clutter up the postings. If anybody wants it I'll post it.
Poly in poly?
« Reply #6 on: June 15, 2005, 10:21:13 PM »
If you are simply getting a point list this will do it.
(setq pline (car (entsel)))
(setq ent (entget pline))
(setq coords (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 10 (car x))) ent)))
This would not take bulges into account.
mohobrien
Poly in poly?
« Reply #7 on: June 15, 2005, 10:33:26 PM »
I like it. I don't do any programming very often but once in a while I have a need and basically crib what I can from all sources available. I'll post the whole routine tomorrow via a link to the lilly pad. Actually while the routine I used is a little cumbersome for just the coordinate list, there are a few other items I need from the the assoc lists (don't know the proper name to call them) that I grab at the same time. Perhaps grabbing the info the way you suggest may be cleaner.
 The more I look at your suggestion the cleaner it looks. I think a rewrite is due.
mohobrien
Poly in poly?
« Reply #8 on: June 16, 2005, 10:12:58 AM »
http://www.theswamp.org/lilly_pond/mohobrien/esriout.LSP?nossi=1
http://www.theswamp.org/lilly_pond/mohobrien/esriout.dcl?nossi=1
http://www.theswamp.org/lilly_pond/mohobrien/WriteShp.dvb?nossi=1
The routine is for converting polygons, some with holes, some with islands into esri shape files. The dbf gets its data from attached object data. I tried to write the whole routine in lisp but couldn't get past the need to write to a binary file. Thats why I use the WriteShp routine.
Please tear it to shreds and give more suggestions for improvement.
I guess I should have given a test data set.
http://www.theswamp.org/lilly_pond/mohobrien/Testdata.dwg?nossi=1
Is object data as I'm using it available in vanilla cad or is it only in map? Maybe this should be in the geographicaly afflicted forum. :)
