Author Topic: area in text  (Read 1690 times)
ampm6170
area in text
« on: June 15, 2005, 11:38:50 AM »
i need to find out the area of many rooms and show the area on the drawing. instead of plugging those numbers (areas) everytime by using TEXT , is there any other quicker way to do the numbering after checking the area?
thanks
area in text
« Reply #1 on: June 15, 2005, 11:50:54 AM »
Try this:
;Puts text with objects area in it unless it is 0.00*------Many thanks to the SWAMP.ORG for all the help
(defun c:rat (/ *error* u-clayer getboundingbox llc urc s1 index ent obj bbox mpt obj_area txt deltext a n)
(setq a 0)
(command ".undo" "begin")
   (command ".style" "arial" "arial" "" "" "" "" "" "")
   (prompt "\nARIAL is now the current text style")
;_____________________________
;Error function
(defun *error* (msg)
      (not
        (member
          msg
          '("console break" "Function cancelled" "quit / exit abort" "")
    ) ; if
(setvar 'clayer u-clayer)
  ) ;end error function
;Get User Variables
(setq u-clayer (getvar 'clayer))
(if (tblsearch "layer" "area")
  (command "-layer" "thaw" "area" "on" "area" "")
  (princ "\n Layer 'area' Created")
(command ".-layer" "m" "area" "")
  (defun getboundingbox (obj / minpt maxpt)
    (vla-getboundingbox obj 'minpt 'maxpt)
    (mapcar 'vlax-safearray->list (list minpt maxpt))
    (setq llc (vlax-safearray->list minpt)
          urc (vlax-safearray->list maxpt)
    (list llc urc)
  (if (setq sl (ssget '((0 . "LWPOLYLINE,CIRCLE,REGION,POLYLINE,ELLIPSE,SPLINE"))
      (setq index -1)
      (while (< (setq index (1+ index)) (sslength sl))
        (setq ent (ssname sl index))
        (setq obj (vlax-ename->vla-object ent))
        (setq bbox (getboundingbox obj)
              llc (car bbox)
              urc (cadr bbox)
              mpt (list (/ (+ (car llc) (car urc)) 2) (/ (+ (cadr llc) (cadr urc)) 2))
        (setq obj_area (vlax-get-property obj 'area))
        (setq txt (strcat (rtos obj_area)))
        (command "text" "j" "mc" mpt (* (getvar "dimscale") 0.15) "0" txt)
(setq deltext (setq s1 (ssget "x"'((0 . "Text")(8 . "area")(1 . "0.00*")))))
(command ".erase" deltext "")
(*error* "")
(princ (strcat (itoa index) " entities processed..."))
      (setq n (1- (sslength sl)))
      (while (>= n 0)
(command "_.area" "_o" (ssname sl n))
(setq a (+ a (getvar "area"))
     n (1- n)
      (prompt (strcat "\n The TOTAL AREA of " (itoa index) " processed items = "
        "\n" (rtos (/ a 1) 2 3)" sq. ft."
  "\n" (rtos (/ a 43560) 2 3)" acres"
        "\n~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~"
        "\n" (rtos (/ a 144) 2 3)" - this number converted sq. inches to sq. feet (architectural units)"
  "\n" "Be aware that unclosed polylines and splines"
  "\n" "have an area too and will be accounted for if selected..."
      (alert (strcat "\n The TOTAL AREA of " (itoa index) " processed items = "
(command ".undo" "end")
Crank
area in text
« Reply #2 on: June 15, 2005, 03:01:02 PM »
I say: FIELDS :P
Don't have a clue how to do that in lisp, but fields are so for this.
