Use INSERTOBJ command in Autolisp or equivalent
FELIX:
I want to insert unreferenced images like OLE.
Have an example of INSERTOBJ or an equivalent Autolisp function?
hmspe:
I use code like this. This is to insert in model space, scaled based on DIMSCALE.
(defun setpower ()
(if (null (tblsearch "layer" "power"))
(command "-layer" "make" "power" "color" "cyan" "power" "")
(setvar "clayer" "power")
(defun enco_insert (symbol / ds)
(setvar "cmdecho" 0)
(setpower)
(setq ds (getvar "dimscale"))
(prompt "\nSelect insertion point... ")
(command "_insert" symbol "PS" ds pause ds ds pause)
FELIX:
I need to insert a JPG image and not a block. OK?
MP:
Start with the entmake function if you understand how dictionaries work (e.g. "ACAD_IMAGE_DICT") or the AddRaster method of Paperspace / Modelspace if you prefer the ActiveX route.
MP:
Q & D ...
--- Code: ---(defun _add-raster ( owner image-path point scale rotation / result )
(eq 'vla-object
(type
(setq result
(vl-catch-all-apply
'vlax-invoke
(list owner 'AddRaster image-path point scale rotation)
result
--- End code ---
--- Code: ---(setq raster
(_add-raster
(vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object)))
"C:\\Users\\MP\\Pictures\\The-Answer-Is-42.png"
'(0.0 0.0 0.0)
1.0
0.0
--- End code ---
Cheers.
Navigation
[0] Message Index
[#] Next page
Go to full version
